99 LX470 door sensor problem
i got a problem with my door sensor, it detects a door is not closed but they are all closed and whats worse is that i cant turn the alarm on now....the keyless entry doesnt accept it to turn the alarm on....please help if you know
Try the easy stuff first.
Rusty contacts. Test each door contact by manually depressing the switch of each door while watching the dash lamp. If one of the switches is bad...then you will not see thedash lamp go on and off when you manually depress the switch.
JCIS250RWD
Oct 30, 2021 01:34 PM
BinaryJay
May 24, 2020 07:31 PM
GRANYZ400
Nov 25, 2014 07:20 PM
