What if?
Old May 7, 2025 | 01:58 AM
sajack's Avatar
sajack
Default What if?
This is strictly a hypothetical question, but what if a person is driving an LS500 and experiences a coronary infarction and passes out?
Should the passenger:
1. Grab the steering wheel and try to steer
2. Push the start/stop button
3. Attempt to crawl over the console and reach the pedals
4. Push the emer. brake button
5. Tap the left paddle shifter and down shift
6. Shift into neutral.
7. Reduce speed with cruise control buttons if cruise is being used
8. Use a combination of some of the above
Old May 7, 2025 | 04:31 AM
Fhobbs's Avatar
Fhobbs
and
9. Pull drivers right leg off gas pedal (assuming not in cruise control), otherwise, hit the cruise cancel button
Old May 7, 2025 | 05:45 AM
offroad200's Avatar
offroad200
I would add press the SOS button and hopefully they are enrolled.
Old May 7, 2025 | 06:39 AM
sajack's Avatar
sajack
I still like the old manual emer. brake handle next to the console like I had on my Miatas. Light pressure on it would help to slow things down.
Old May 8, 2025 | 01:44 PM
GrandSedanFan's Avatar
GrandSedanFan
I would, if possible, clear the driver's legs and activate the DRCC and LTA as quickly as possible and then reduce speed via the DRCC buttons. Also, turn on the hazards and press the SOS button. At minimum speed, if the car does not come to a stop due to traffic, pull and hold the electronic parking brake button - my hope is that it will activate which will abruptly stop the car. If not, then I remove my seat belt and climb over to brake manually.
DMPesso
Aug 19, 2021 10:24 AM
ocr
Jun 27, 2012 08:40 PM
Lexs400
Jan 20, 2004 03:14 PM
