2024 LS. Was running behind yesterday and didn’t have time to fuel up when I wanted.
The distance to empty hit 50miles, no light no warning. 30 miles DTE. Nothing. Finally with 22 miles to empty I got a “Low Fuel” warning in the display and a little orange fuel light came on.
It’s not a huge deal but is that normal the car only warns at basically 20 miles left? I’ve had several other Lexus and Toyota models before and they all had fuel lights come on way way earlier than this.
Seeing that your car is a 2024, can you not set the threshold mileage for the warning?
In my last car (not a Lexus) I was able to specify the mileage at which the warning should come.
I have not. I will pull out the owner's manual too. Thanks for the suggestion, worth a look.
I wouldn't trust the DTE. Toyota products are very conservative on stuff like this. I did a run-to-empty test on my Tundra, and once the low-fuel light illuminated I went 80 miles before the engine started have fuel starvation. When the low-fuel light illuminated the DTE was 20 miles, then it when blank. That figures to at least four gallons remaining when the low-fuel light illuminated, on a 26-gallon tank. So for LS I'd estimate about 3 or 4 gallons remain when the low-fuel light illuminates. It's all kind of academic anyway, who runs out of fuel?
My 500h has a 21.6 Gallon tank (82 liters), if the car says the range is 13 Miles (20 km's) then i can only fill the tank with about 19 Gallons (72 liters) so mine has about 2 Gallons or 8 liters safety build in.
( why don't you Americans use the metric system like the rest of the world? )
I think the Ls460's are the same way, once it's below 20 miles of "range" is just says "low fuel level". At that point there's still ~2 gallons left (so 40-50 miles) so plenty of leeway. Only get it that low cruising on the highway when I know there's a gas station every 5 miles.
@Higgie because we like it that way lol we don't teach our kids metric in primary school, we only end up learning it in college if you get a technical degree, then it depends on what company you use that technical degree in. Some companies, use standard (English), some use metric (SI), and some use both!
My gauge seems inaccurate. It lingers around 3/4 full for close to 200 miles, then starts to drop.
Yesterday I filled up in Evergreen, Colorado and drove to Hays, Kansas. My gauge was slightly below 1/2 when I got to Hays. I topped the tank off and was astounded that it only took 10 gallons. Now this is a downhill drive. I was driving 75-80 mph in eco mode.
360 miles on 10 gallons! I was expecting around 27mpg.
Has anyone else gotten this kind of mileage with an LS500?
I can get 25-27 if I am gentile on HW.
Soon as I push it to around 85 drops south of 24mpg.
I am usually not to gentle unless traffic dictates it.
So Lexus is as paranoid about running out of gas as a engineer flying his newly designed airplane. Lol
@PGA71 why are we doing the "2 clicks", you know that could put gas into the evap carbon canister and damage it over time? Or at least I've heard that. I thought gas tanks were deigned to have a certain amount of empty space in them for pressure and vapor and safety or whatknot. (can you tell I don't know how to design a gas tank? ) You do you, but just curious.
I usually don't like doing it, but for this use case I wanted to make sure it was relatively full and not a misclick. But you are correct, we should not be overfilling.
