2012 ls460 rwd ball joint
Old Mar 20, 2022 | 06:56 PM
Mastiffman's Avatar
Mastiffman
Default 2012 ls460 rwd ball joint
Finally changing out these control arms. Problem though ended up damaging the ball joint removing the lower rear control arm. Would someone plese drop me some info where i can find this part? Online would be great and thanks. Ive looked and the only place i can find this part is ebay. Chinese probably. Mevotech, Beck, Moog all preferred brands. OEM IF i have to.
Old Mar 21, 2022 | 07:39 AM
bearcav's Avatar
bearcav
Did you mean front? I don't think the rear has a ball joint...?
Old Mar 21, 2022 | 08:01 AM
Mastiffman's Avatar
Mastiffman
Right the joint pressed into the spindle arm. This is what rear lower control arm attaches to on the front wheel of a RWD model. Sorry maybe needed to clarify.
Old Mar 21, 2022 | 08:57 AM
bearcav's Avatar
bearcav
I'm still confused but I think you're looking for the "rearward" FRONT lower control arm? These cars have a 2-piece "LCA", one attaches the shock and steering knuckle (lower control arm), the other goes to the steering knuckle only (control arm reinforcement). You keep saying ball joint (which itself is an actual part bolted under the steering knuckle) even though many things have a "ball joint" (like the tie rod end).
Regardless, here are all the part numbers, you know your car and can locate the item you're looking for. You might be having trouble locating the part because you're calling it a "rear lower control arm" which is a completely different part on the back of the car. https://parts.belllexusnorthscottsda.../a1_484980.jpg
Old Mar 21, 2022 | 09:08 AM
Mastiffman's Avatar
Mastiffman
Default What is this attached to the spindle called if not a ball joint?
Old Mar 21, 2022 | 09:12 AM
Mastiffman's Avatar
Mastiffman
Default Ball joint?
Old Mar 21, 2022 | 09:44 AM
bearcav's Avatar
bearcav
https://burjauto.com/oem/4320259075-...ing-lh/8525011
https://parts.belllexusnorthscottsda...320259075.html
Looks like its all one unit w/ the steering knuckle, no official part number for that so I wouldn't expect any of the major brands to sell it. If you have the dimensions maybe you can call them and see if they have a suitable part.
Old Mar 23, 2022 | 04:58 AM
sha4000's Avatar
sha4000
It's one unit with the steering knuckle. Do a search on this site and you will find plenty of info on this topic.
Old Mar 23, 2022 | 05:50 AM
Mastiffman's Avatar
Mastiffman
Default Found ball joint on Amazon. Received parts look great
Thanks! Pressing them in today I'll have 8 new control arms with new ball joints installed by Saturday. Thanks everyone for your help.
ZamoraLex
Feb 13, 2023 04:47 AM
icon901
Oct 12, 2021 02:23 PM
truviethug
Nov 15, 2020 09:52 AM
Walking
Mar 1, 2018 11:32 AM
Speedc4s
Dec 13, 2016 08:39 AM
