My horn does not work...
Old Jul 18, 2021 | 08:30 AM
USCRugby's Avatar
USCRugby
Default My horn does not work...
Over the past few years the horn would work and then not work. It would work mostly in the cold months and not so much in the summer. (Charlotte, NC) Recently, it has stopped 100% and I need to get it fixed. I think I need to check the fuse, but I don't know which one to buy nor do I know where the fuse box is located. I would appreciate some help with this. Please treat me like a 6 year old. LOL
I think it's a short somewhere and not a fuse, but I am FAR from an expert! Thank you for your help as always!
Old Jul 18, 2021 | 06:31 PM
fwhomeboy's Avatar
fwhomeboy
Start reading here...
https://www.clublexus.com/forums/ls-...t-working.html
Old Jul 18, 2021 | 06:33 PM
fwhomeboy's Avatar
fwhomeboy
Another good read...
Old Jul 18, 2021 | 06:52 PM
fwhomeboy's Avatar
fwhomeboy
I couldn't find my horn problem and mine stopped working for 3 months and then yesterday it worked when I hit it but, it won't work tomorrow I'm sure. I quit worrying about it but I just need it to work in February when it's time for inspection. Good luck Sir. I think it's this North Carolina GAS. (Greensboro)
Old Jul 19, 2021 | 10:54 AM
USCRugby's Avatar
USCRugby
Originally Posted by fwhomeboy
Thanks, but you linked to the same thread!
Old Jul 19, 2021 | 11:12 AM
USCRugby's Avatar
USCRugby
I found this on YT.
Old Jul 22, 2021 | 10:40 AM
USCRugby's Avatar
USCRugby
I wish you guys would have said that these are not size fuses. I purchased some from Amazon and they were very different in size. If everything else works with that fuse, would simple logic say something is wrong with the horn system itself?
Old Jul 26, 2021 | 02:30 PM
fwhomeboy's Avatar
fwhomeboy
Hey, Did you find the problem yet?
Old Jul 28, 2021 | 09:36 PM
Zetascry's Avatar
Zetascry
if all fuses look good. Then safe to say its either your horn itself. If horn is good then according to the symptoms you stated earlier with horn working then not working. You need a new clockspring. search up chrisfix on youtube and its fairly easy install. good luck.
Old Jul 29, 2021 | 06:39 AM
Kansas's Avatar
Kansas
My intermittent horn was caused by a defective horn pad / air bag assembly. The horn worked reliably after the assembly was replaced. Have the problem diagnosed by a pro. A Lexus tech figured our my horn problem in a few minutes.
Old Aug 9, 2021 | 08:42 PM
USCRugby's Avatar
USCRugby
UGG how much did that run you?
edvc520
Dec 1, 2022 09:46 AM
SLVRGS
Mar 31, 2022 10:30 PM
Bobzi
Aug 31, 2017 07:43 PM
smarshall9
Mar 20, 2009 04:53 PM
Bentley1
Aug 3, 2008 10:41 PM
