ABS Actuator - Highest mileage without replacement
Old Jun 7, 2021 | 06:36 PM
eelliiss's Avatar
eelliiss
Default ABS Actuator - Highest mileage without replacement
Hello all,
Big lurker here. This forum has been a tremendous resource to me for research over the years. We just got my wife a 2010 LS460 with ~130k miles and great service records. Services done every 5k miles, interior panels replaced, all front control arms replaced, new steering knuckles, etc. It's a real pleasure to drive.
I know this topic has been covered quite a bit, but I'm curious if it's not a matter of IF the ABS actuator will fail, but WHEN. I read a handful of threads, and I also saw the thread with the poll in it. Is there anyone who has a very high mileage LS460 that hasn't required replacement? Previous owner had the brakes serviced at the dealership, and I presume everything was flushed at that point, too. Fluid is clear and light when I look at the reservoir. I may flush for peace of mind.
Chime in and let me know what kind of mils you have on your original ABS actuator.
Thanks!
Old Jun 7, 2021 | 06:41 PM
roshko's Avatar
roshko
205k on mine. Regular fluid changes at dealer, no issues.
Old Jun 7, 2021 | 07:51 PM
miket000's Avatar
miket000
189k on my 2007. The electric motor has been running / charging more than usual for the past 3 years. I have been sucking the old fluid out of the reservoir and replacing with fresh fluid a few times a year. This year the brake motor starting running repeatedly 3 or 4 times in a row. I sucked the fluid out and it went back to normal. It hasn't thrown any codes. I think doing a proper brake fluid flush at this point may be the final nail in the coffin.
Old Jun 8, 2021 | 04:17 AM
Anfanger's Avatar
Anfanger
Do periodic brake fluid flush and you should be OK.
Old Jun 11, 2021 | 06:49 AM
JLAWS's Avatar
JLAWS
Changing the rubber brake reservoir cap doesn't hurt either. Get oem of course. A new one seals much more tighter.
Old Jun 11, 2021 | 08:23 AM
jud149's Avatar
jud149
Just 65k on my '11 when it went. The car was 9 years old then.
Old Jun 13, 2021 | 12:04 PM
sktn77a's Avatar
sktn77a
Had 100,000 miles on my '07 on original actuator when I sold it. My 2014 actuator had to be replaced at 30,000 miles.
Old Jun 15, 2021 | 04:48 AM
Doublebase's Avatar
Doublebase
I was at 179,000 miles in my 2007 when the actuator finally started making noises whenever I stepped on the brake. Knew it was only a short matter of time, so I traded it in.
But I did do brake fluid flushes on it...I don’t think THAT really helps. Thought about buying a used actuator off eBay, but the car had other problems...burning oil, needed tires, brakes, interior was starting to melt on the drivers side arm rest, needed a passenger side mirror (a turkey hit it on the highway). But I loved that car! Put most of that Mileage on it in four years...was averaging 26 mpg when I got rid of it. Probably could have gotten another 100,000 miles out of her with a little effort.
Old Jun 18, 2021 | 10:29 PM
LexusManny's Avatar
LexusManny
My brake actuator had to be replaced at 165k miles on my POS 2008 Lexus LS460. Bought actuator online from lexus dealer for $995 plus $200 install at indy mechanic.
I need to add this item to the top 5 issues on my LS460
pax
Mar 11, 2021 04:29 PM
Wandl
Jan 4, 2020 11:53 AM
icon901
Dec 8, 2019 10:09 AM
StarkGs460
Oct 9, 2018 06:30 PM
Kadrian21
Mar 6, 2017 12:05 PM
