LS460 Fog Light Mod
Old Jul 2, 2020 | 10:04 AM
kuWuPt's Avatar
kuWuPt
Default LS460 Fog Light Mod
The LS460's fog lights from factory only comes on with the low beams on. With the high beams on the fog lights turn off. Wanted the flexibility of being able to turn on my fog lights, independent of the headlights. Want to thank Shibumi1 for documenting his version of the mod, I just modified it to do what I wanted. I did not want the fog lights on all the time nor did I want to put in another switch. I just wanted my fog lights on when the park lights come on and also full functionality of the factory fog light switch. The wiring diagram below is how I wired everything up.
The baby blue wire below is the ground signal for the fog light switch. It is located under the steering column, just remove the plastics of the steering wheel column and the picture below is what you see with the bottom plastic piece removed.
(picture courtesy of daniel1235)
For the harness I planned on mounting all the relays etc up front behind the bumper support so ran the fog light ground signal wire from under the steering column through the firewall into the engine bay to the front behind the bumper support. Soldered all the wires, heat shrunk every connection and made a nice harness with some techflex wire loom. The below shows the harness but with some extra wires etc I wanted to run that ties in to the front I plan on doing later. Also the harness has a fused power wire to run the HID's for the fog lights.
The relays mounted behind the bumper support.
For the fog lights to come on with the park lights, I tapped into the yellow wire on the harness that is connected to the headlights. Picture below shows the orange wire I used in my harness and tapped into the yellow wire.
The JDM fog lights that were modified slightly.
Full write up and larger pictures: Flawless Fitment
Old Jul 2, 2020 | 08:50 PM
cryptodonis's Avatar
cryptodonis
Thanks so much for taking the time to share this. Adding similar functionality for the fog lights has been on my list for some time but I have decided to bite the bullet and save for the JDM fogs first so it will likely be a while still before I do so. Looks great and can definitely appreciate the super clean install!
Old Jul 2, 2020 | 08:53 PM
cryptodonis
How did you further modify the fogs? It looks like similar color and control functionality to demon eyes?
Old Jul 8, 2020 | 09:29 AM
kuWuPt's Avatar
kuWuPt
Thank you.
The factory LED bulb was just disconnected and I put a RGB LED strip inside, behind the plexi. Same as the demon eye setup, in fact if you have demon eyes you can just connect the 4 wires from the LED strip to the same demon eye controller.
Old Jan 23, 2023 | 04:22 AM
Fsportdrvr's Avatar
Fsportdrvr
Would this work on the 2013+? Or would the 12v be too much since the newer are an led strip?
Old Jan 23, 2023 | 06:24 AM
swfla's Avatar
swfla
The voltage is important as you know. If the led strip doesn't have a voltage regulator built in, you will need to find a 5V ?? source. I'd measure the current voltage going to the OEM fogs that you already have on the car.
Old Jan 23, 2023 | 06:35 PM
Gerf's Avatar
Gerf
Wrong thread.
Old Jan 24, 2023 | 09:19 PM
mikemc12's Avatar
mikemc12
Sorry for being a noob, but by "park lights" do you mean the DRLs?
I am trying disable my DRLs and use my fogs as DRLs, then change the high beam to LED and retain the high beams function.
Old Aug 7, 2024 | 10:49 AM
Diab's Avatar
Diab
All I want is for the fog lights to turn on, on demand, regardless of main headlight setting.... without all the intense wiring mods... is there no plug-and-play options?
Uzairlexus
Hybrid Technology
Sep 22, 2020 02:51 PM
n/aisweak
Apr 20, 2017 10:06 AM
bpate
LX - 3rd Gen (2008-2021)
Dec 26, 2016 04:21 PM
daniel1235
Dec 3, 2015 05:32 PM
VinnRock
IS - 1st Gen (2001-2005)
Mar 11, 2009 11:49 AM
