Large Oil Consumption...
Old Nov 2, 2019 | 07:37 AM
ajh77's Avatar
ajh77
Default Large Oil Consumption...
So I purchased my 2008 LS460 on August 31st from Carmax the car had 111,250k
I paid a local Lexus dealer to do a pre-purchase inspection the following day and that took about 4 hours and they said the car was a-ok.
Just for curiosity sake I checked the oil at 111,650 and it was quite low so I topped it off.
Today I checked the oil, engine was cold, current mileage 112,600 and the oil indicator is well below the last circle on the dip stick
The oil level indicator has not come on and the car runs fine
There are no visible leaks on the ground
I do have a CNA warranty that will kick in at the end of this month so I was thinking about bringing it to a Lexus dealer then for this issue.
Does anyone have any other suggestions ? What is the main cause of such a large amount of oil usage in such a short amount of time ?
Old Nov 2, 2019 | 09:02 AM
colfax's Avatar
colfax
oil consumption on these big V8 Lexus motors has long been a reported thing
my 07 460 uses a quart of oil around 1300 miles of driving
Old Nov 2, 2019 | 10:14 AM
Thegamemhb's Avatar
Thegamemhb
Did you yourself topped the engine oil ?
Was the engine cold or hot at the time of topping
Which oil did you use ?
Any smell or smoke that you noticed ?
Old Nov 2, 2019 | 07:03 PM
ajh77's Avatar
ajh77
I topped it off, it was hot
I used 5w-20
No smoke or smells
So I just calculated, in 1068 miles the engine went through 2 quarts
Old Nov 2, 2019 | 07:12 PM
Thegamemhb's Avatar
Thegamemhb
I used 5w-20
No smoke or smells
I think it was because of hot engine next time do it when the engine is cold and do a full drain and refill
Its a good thing that there is no smoke or smell .. still 2 quarts is alot i am doin complete drain and refill with filter at every 6000-7000 miles i am doing highway 70% and city 30%
Old Nov 2, 2019 | 07:17 PM
ajh77's Avatar
ajh77
Ok, thank you, but how can putting two quarts of oil in a hot engine make it leak or evaporate faster vs. if I put it in when the engine is cold?
Old Nov 2, 2019 | 07:38 PM
Thegamemhb's Avatar
Thegamemhb
Its not the hot engine or cold that is making it disappear according to my understanding it was the previous oil that was in the engine that is why i told you to drain and refill it properly i am not sure about the value but the oil i am using here in dubai is two big bottles and one small usually if i go to any local garage they just fill with two bottles and dont care about the small bottle so i buy the oil myself and refill it properly .
You were not sure about the viscosity of the previous oil aswell .. and by cold engine i mean a 3-4minutes of engine time so the oil can get warm and easily drain
Here is something .
Synthetic oil has a higher rate of expansion and contraction with temperature changes. These blends will be much tighter when cold and could expand even more than expected when hot.
Regular oil will experience normal expansion and contraction, which means you will get around the same readings regardless of temperature.
Old Nov 2, 2019 | 07:58 PM
Thegamemhb's Avatar
Thegamemhb
This might help .
Old Nov 4, 2019 | 06:27 PM
sktn77a's Avatar
sktn77a
I've had 2 LS460s and never had an issue with oil consumption - dino oil in the '07 and synthetic in the '14. Oil consumption shouldn't be an issue it these cars. If you have excessive oil consumption and there's no sign of a leak, then it is being burned. Having said that, if it's an older car then it's cheaper to just keep topping it off than to undertake major engine surgery.
Old Nov 4, 2019 | 06:33 PM
Sportznuts's Avatar
Sportznuts
You are now realizing the negative of posting on a Lexus forum where people can’t possibly imagine that you have a real problem. It may be unique, but it’s real. And most of the responses are basically saying, “there isn’t a problem, you are only imagining it.”
If you are going through that much oil there is a major problem.
Old Nov 4, 2019 | 09:18 PM
Thegamemhb's Avatar
Thegamemhb
First off he checked the oil on hot engine
Second hes not having any burning smell from engine bay
Third no smokes from exhaust
Fourth no missfire
How can you say hes having a major problem ?
Old Nov 4, 2019 | 11:34 PM
sha4000's Avatar
sha4000
My car is down below the first dot around 3500 miles after the oil has been changed. This is 90 percent highway and I'm a very spirited driver. I won't say it's normal but it is a common issue on this forum. The GS also started to burn oil so I pulled the manifold and spark plugs and soaked the pistons and valves with seafoam for 2 days. The low oil light has not come back on and I'm into the second oil change. I won't be satisfied it's fixed until 2 to 3 more oil changes though. That engine has 160k on it.
Old Nov 7, 2019 | 01:30 PM
Leximum's Avatar
Leximum
I bought my 2013 LS AWD last year and lately, I came across a paragraph in the owner's manual, which indicates that it is normal that my car WILL consume oil.
Can some of our members with knowledge on the engine and auto-mechanics tell us the difference between consuming oil and burning oil? I think, as owners of these fancy machines, we need to gain more understanding about the subtle difference!
Old Nov 7, 2019 | 07:10 PM
Jasoneo5's Avatar
Jasoneo5
I used to consume oil, largely coming from the fuel pump gaskets leaking. I put some easy DIY sealant around those and switched to 5w30 and no more leaks. That was 30k miles ago.
Old Nov 8, 2019 | 01:59 PM
Leximum's Avatar
Leximum
Default Oil consumption
I never would have connected the fuel pump gasket could affect oil consumption.
How did you test it or confirm it from the beginning?
