Radio / Stereo randomly shuts down.
I am thinking it could be temp related so this summer I will not be surprised if starts again.
If this starts happening again when the weather gets warmer... I would for sure look into the soldering things said above. it would sound like a bad solder joint to me.
Check the main grounding strap under the battery. It may be coincidence but I had to replace the bolt connecting the ground to the frame because of corrosion and have not had the problem since. But I have not had the car sitting in the sun all day either. My IS250 would not start one day and as soon as I connected jumper cables to ground it started with no second battery connected.
I had the same exact problem a few times over a year or so. Stereo spontaneously turning off, CD ejecting, but still able to restart it. It was getting worse in the past month.
After reading some of these posts about it being an electrical short, I decided to slowly push around on the plastic on the console and see if I could provoke it. When I pushed hard on the space just below the cd slot and above those lower controls, I could get stereo to turn off exactly when I would push there.
Kind of impulsively I decide to bang a little harder with the bottom of my fist a few times in that spot to get whatever two pieces of metal that were touching to maybe clear each other. I know it could have gone the other way and I could have made it worse, ... but it worked. I haven't had the problem since, about a year ago.
Mark Levinson model
Mark Levinson model
Kalogerus
Apr 24, 2022 04:32 PM
usna2011
Jan 31, 2010 04:40 PM
