battery change on LS460 - all electrical not functioning
Old Jan 7, 2018 | 02:39 PM
Canoe's Avatar
Canoe
Default battery change on LS460 - all electrical not functioning
Everything limited. Braking system locked can't drive car. any suggestions
Old Jan 7, 2018 | 03:22 PM
fwhomeboy's Avatar
fwhomeboy
These guys on here are good but, You're gonna have to give a better story than that. They will need more info to help you fix it quick. Tell us the whole story, Please.
Old Jan 7, 2018 | 03:38 PM
Canoe's Avatar
Canoe
sure thanks. My battedy was weak so i pickednone up on ghe wayto the gun club. Sure enough when i went to leave. The battery was completely dead. I swapped it out and upon starting the car all electronics are severel limited and the braking system is locked preventing me from driving. It said check the vcs, check the pcs, pull over safely brake malfunction. Im stuck and in a snow storm
Old Jan 7, 2018 | 03:52 PM
jmcraney's Avatar
jmcraney
Is it possible you changed your battery without turning the ignition off?
Anyway, what you need to do now is turn your ignition off and then disconnect the negative terminal of the battery for a few minutes. Then reconnect the battery and start the car as you normally would.
fwhomeboy's Avatar
fwhomeboy
OK, So, I remember that there is a certain way you have to let the car reprogram the the system but, I don't know the procedure but, the guys on here will know what to tell you. Sorry I couldn't be more help but, now, they know how to steer you in the right direction. Standby.
Old Jan 7, 2018 | 04:01 PM
Canoe's Avatar
Canoe
Thanks. The car battery was completely dead when i went to start it
not so much as a click. Rather than boost it from the new battery which i did this morning no problem i swapped it out and thats when my problems all came up. I have the negative terminal disconnected in the hopes that someone on this forum may be able to assist me. I can start the car but again everything is not functioning and the braking system is locked up and cant be released.
Old Jan 7, 2018 | 04:28 PM
Canoe's Avatar
Canoe
Anyone have any suggestions?
Old Jan 7, 2018 | 04:44 PM
jmcraney's Avatar
jmcraney
I am working with very little information. You seem to be in a "snow storm" and you believe that your brakes are locked and that is related to replacing your battery.
I think you have to consider that your brakes are not locked, but that your car has frozen to the driving surface or that you don't have any traction because of ice or a combination of that.
Since you are in a "mess," don't worry about those lights. They will not keep you from driving your car. The lights are probably related to the battery replacement and we can help you deal with that when conditions are safer.
Old Jan 7, 2018 | 04:53 PM
jmcraney's Avatar
jmcraney
If your parking brake has become set, some how, be sure to release it.
Old Jan 8, 2018 | 05:15 PM
elsonido's Avatar
elsonido
I know it's to late now but there is a neat little item you can buy on-line that will allow you to save all your settings. It plugs into your lighter and it has a connection for a 9 Volt battery on the other side. It's called a memory saver. Some also have a pair of gator clips you can attach to the + & - terminal cables under the hood as you disconnect you dead battery. Just be sure doors and all lights are closed. Disconnect before you turn on the ignition.
Old Jan 14, 2018 | 09:23 AM
My1998LS40's Avatar
My1998LS40
Could you possibly put the battery back in with the terminals switched around. Your big main fuse block could be burnt. Check that. With the symptoms you’re having, I’m pretty sure your fusible links could be burnt.
Old Jan 14, 2018 | 07:30 PM
roadfrog's Avatar
roadfrog
Could we get an update OP?
azzkicker
Jan 21, 2021 07:05 AM
jerryh1948
Aug 27, 2018 12:33 PM
JZog
May 30, 2017 08:53 AM
hksnlper
Oct 30, 2016 08:14 PM
texas008
Mar 27, 2015 05:52 PM
