For those with a model with uncracked vents, I would suggest that you buy some epoxy and take a piece of thin metal or plastic and bond it along the entire length of where it is known to crack. This way the material cannot flex and distort over time.
thats a great idea... now how to do that effectively is the key
need pry tools that are a little more soft around the edges or cover it with a thin eye glass cleaning cloth
Sadly the plastic is too brittle at the edge...the pry tool is plastic so it's ok. One thing I have to say is the clips retention force is great...little bit too much for this issue.
gotcha will bear in mind when i have to take my trim out thanks
Mine cracked on a 70 degree day. Think the dashboard expanded and caused it to crack, That was before the dash was replaced. I found a good used one on ebay for $100. All i had to do was swap the nav screen. Easy job. So far now 2 years later no new crack.
Be careful prying out the Radio & Nav with the trim pry tool. The surrounding areas of the dashboard can crumble. Then you have another eyesore to look at.
Great work, so glad I found this. I have absolutely identical issue + the flaking off directly above the volume **** and recently I was thinking how to take on something like that. I’m happy it didn’t require any disassembly.
Good to know... Thanks for the info, just in case it's needed at some point...
It looked like a time consuming project but, MUCH better than paying $800+ for a fulll navi head !
Do you happen to know what this plug is for? I know it plugs into the bottom climate control unit but what does it control? Im curious because if the big harness that is plugged in is that powering only the climate control? I know the climate control also is built in with the passenger airbag off/on circuit board. I hope you can answer me. I will attach a photo
