Maintenance questions.
1. Should Synthetic Oil be used for oil changes (even if I have to pay extra)?
2. Is the recommended service interval 5000 miles/6 months whichever comes first? (I was just told it was 5,000 miles, nothing about the time interval. If 6 months go by at less than 5000 miles, should I still bring it in?)
3. I bought the free-maintenance contract (it's for 30,000 miles). Should I ask for anything in particular to be checked/replaced/etc. at the dealership when I get each service?
4. Anything else to keep an eye on?
Thanks in advance.
2. Unless it takes you more than a year to go 5000 miles, I would just stick to the mileage interval and forget about the time interval.
3. I would just make sure they check everything that is scheduled to be checked for that particular mileage interval.
4. The big smile you see when you look in the mirror!
Lexus recommends synthetic 0W20 on this generation LS460, changed every 10,000 miles. I would only use that, using non synthetic oil is asking for problems if you ever do have a warranty issue. Service is done every 5k, but that service is basically just a tire rotation...oil changes are every 10k.
Because of a recent conversation with my mechanic, I have decided to start changing the oil every 5k. He feels that with the direct injection and the timing chain Lexus' decision to go to 10k intervals wasn't wise, and he recommended to me that because I may decide to keep this car for the long haul it was worth the additional expense to change the oil every 5k. I did 10k changes until the service I had done last week (35k) where I changed the oil again despite having it changed at 30k.
So thanks SW15ls!
Actually, I was surprised reading the 2014 LS manual (P. 842) that it does not ask for synthetic oil. I don't see where Lexus recommends synthetic. I'll try looking online to see if they changed this.
It just says "Toyota Genuine Motor Oil" or SAE0W20 (or 5W20 if 0W20 isn't available). The oil type is "ILSAC GF-5 multigrade motor oil." on page 916.
My Benzes in the past required synthetic.
I have always used Mobil 1 in all my cars back to Toyotas/GM cars and thought for sure the LS would require it. But apparently not.
So I guess I have to try and insist that they use it.
5,000 miles is the recommended oil-change interval, but I guess that's because they assume conventional-motor-oil use.
I absolutely would like 5000 mile intervals AND Mobil 1, and I have to see if my free-maintenance agreement would handle that (an extra charge that's not too big I hope).
Your owners manual says 5,000 miles is the recommended oil change interval? My 2015 (same car) says 10k. I think if you look at your maintenance schedule it will show oil changes every 10k miles.
I would recommend buying your oil at Walmart. I hate Walmart, BR nobody is cheaper than them for oil. I buy 5qt jugs of Mobil 1 there for $25.
Of course everything I wrote can be debated (and is debated regularly on oil change forums), but I've seen what long oil change intervals can do to chains...and I've seen how manufacturers have jumped on the "free maintenance" or free oil changes for three years, bandwagon. And I've read about CAFE regulations that manufacturer's worry about, it all adds up to pushing these intervals further and further out (and why would they care, their warranties will run out way before anyone will ever see any issues).
The problem with finding out if it's a group 3 or 4 is that these oil companies lie. They don't want to tell you. To keep costs at a point where they can sell it at Walmart and compete with each other they blend base stocks to get it to perform at a certain level, so a "good oil" may have 3 and 4...then the company will run tests and show the results (and I wouldn't trust that either).
But out from what I've read a true 4 base stock will do well in the NOAK test (a test to measure evaporation under temp). It should perform better than a group 3 and not evaporate as much - but then again they could be blending 3 and 4 together to get results, they're not going to tell you...and you'll have to believe their biased test results. The other test that supposedly will indicate if it's a group 4 base stock is the high temperature/high shear test. A group 4 won't shear as easily under high temp, BUT the low viscosity weight oil that is used in the LS (or most cars) shears quicker than say a 5w30, or something higher. The low viscosity weight oils shear. So that too needs to be factored when they do these little tests, like what weight are they actually testing? Because the weight that you're buying may not be what they are showing test results for, and it could be far different.
Just buy a name brand and change it regularly. From my research it looks like Mobil 1 Extended Performance may have more group 4 base stocks than some. Amsoil may have more group 4. And the German oil formulations may have more. But who really knows? They all lie. But the ability for the 0w20 to flow at low temps would lead one to believe that there are some group 4 base stocks in it, how much is anyone's guess.
First change will be in about 9K more miles, and I'll send it off to Blackstone labs to see what kind of condition its condition is in.
My wife's RX300 has been on 10K changes using Mobil 1 since we bought with about 32K miles on it. Has 142K, now, uses not a drop over said interval.
I've used "extended" intervals on all my vehicles for 30 years, now, all on synthetic, never an oil-related issue...ever. Held on to a few of them until they had more than 200K on 'em, too.
Depending on what Blackstone's tests show, that 9 quarts might be good for 20K miles. I'm okay with this.
When I get my Toyotas' oil changed, they call it "Toyota Synthetic Blend". When I get my Lexus oil changed, it's 0W20. Go figure!
