the remote fob will not open he trunk, but the inside trunk open button will
Old 08-17-16, 01:18 AM
Tantrix
Tantrix's Avatar
Default the remote fob will not open he trunk, but the inside trunk open button will
hello guys, so my trunk will not open using my remote fob, so I have to use the inside button next to the driver seat, which will open the trunk successfully.
this means the motor in the trunk is still good right ? I tried hitting the trunk release button on the remote twice, as well as holding it down and still no luck. Only the inside button next to driver seat will open the trunk.
is this enough info to pin point the culprit ? thanks
Old 08-17-16, 05:03 AM
Chuckinnj
Chuckinnj's Avatar
Try replacing the battery on the FOB and if this does not solve the problem, try another FOB (the extra one) if you have one.
Old 08-17-16, 05:33 AM
roadfrog
roadfrog's Avatar
Does it open with the trunk release on the trunk itself?
Old 08-17-16, 07:16 AM
Higgie
Higgie's Avatar
Does the red led on the fob light up if you press the buttom on the fob?
Old 08-17-16, 08:24 AM
Tantrix
Tantrix's Avatar
no it does not open at the trunk using the sticky rubber button.
so now Im thinking something inside the trunk is broken.
Also the automatic trunk close button does not work. Im assuming these are all related.
Old 08-17-16, 08:25 AM
Tantrix
Tantrix's Avatar
yes it does light up
Old 08-17-16, 08:42 AM
comotiger
comotiger's Avatar
Yeah, I agree. It is not likely to be a weak key fob. The trunk opening is fine. It appears to be an electrical problem with the sensor or switch releasing the trunk using the fob/trunk button. Must be independent of the switch that releases (opens) the trunk from the driver seat. Separate fuse, maybe??
If you lower the trunk lid but not shut it, does pressing the fob or trunk button open the trunk? The problem with the trunk closing mechanism may be unrelated.
Old 08-17-16, 09:21 AM
Tantrix
Tantrix's Avatar
the automatic trunk close button in the trunk also does not work.
which electronic component could it be?
Old 08-17-16, 11:12 AM
alanchad
alanchad's Avatar
Default valet lock
Did you make sure the valet lock beside the inside release is not locked?
Old 08-17-16, 11:49 AM
Tantrix
Tantrix's Avatar
u mean in the glove compartment right ? if thats what you mean then yes, i check that button in the glove compartment.
Old 08-17-16, 03:18 PM
Tantrix
Tantrix's Avatar
are some of you saying there's another master switch inside the trunk itself ? why would they put one in glove compartment and in the trunk ?
Old 08-17-16, 11:32 PM
Tantrix
Tantrix's Avatar
also in addition, the trunk courtesy light on the edge does not work. previousll owner said it hasnt worked in a while.
any chance its a blown fuse somewhere ? does anyone have a fuse diagram ?
Old 08-18-16, 06:36 AM
comotiger
comotiger's Avatar
Yes, sounds like fuse-related problems. I suggest you take the car to a dealership. I think many of your issues could be fixed quickly (and relatively cheaply) by the dealer.
FUZCO
03-10-17 05:18 PM
Crusty
12-18-09 11:43 AM
dynamax
09-13-09 09:57 PM
freefax52
07-09-08 10:51 PM
davidbenji
12-18-07 06:40 PM
Quick Reply: the remote fob will not open he trunk, but the inside trunk open button will
