LS 460 Dyno Test
Old Aug 8, 2015 | 12:41 AM
mistrz11's Avatar
mistrz11
Default LS 460 Dyno Test
Hello, I'm owner of Lexus LS 460 '08 RWD with 95,000 miles. Yesterday I made Dyno Test of my car and in my opinion the results are bad. Is anyone doing a dyno test for LS 460 to compare the results?
Is dyno test should be doing in normal mode or pwr ?
Old Aug 8, 2015 | 03:27 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Welcome to Club Lexus!
Can't read the words to know what is plotted, but something looks wrong with your dyno or the dyno scale. HP and torque should cross at 5252 RPM on every dyno
hp = (torque x rpm) / 5252
The only other dyno I found posted is here though and also doesn't cross there but the numbers look consistent with a 20 pct drivetrain loss
http://www.rri.se/popup/performanceg...p?ChartsID=750
Old Aug 9, 2015 | 05:04 AM
tbilisi79's Avatar
tbilisi79
I always wanted to do this, or run the car in a quarter.
I thought the 385 HP would be a lot stronger.
Old Aug 9, 2015 | 12:38 PM
Tec80's Avatar
Tec80
308RWHP is right on the money if you consider the std. avg. 20% driveline loss.
Old Aug 9, 2015 | 12:46 PM
Nospinzone's Avatar
Nospinzone
Is this an American spec car?
Old Aug 9, 2015 | 02:38 PM
swfla's Avatar
swfla
Thanks for the interpretation. Numbers didn't look right.
Old Aug 9, 2015 | 09:04 PM
Vvman's Avatar
Vvman
TS graph is in newton meters hence we will not see the intersection at 5252rpm.
The appropriate formula in this case should be Horsepower = (nm x rpm) / 7121
Plucking some figs from the graph above and working backwards,
418nm at 3920rpm translate to 230.1hp
308hp at 6199rpm would translate to 353.8 nm
Both numbers correspond to their respective points on the graph and hence probably legitimate.
Alternatively, you can convert nm to lb/ft first and compute using the 5252 formula.
Rpm at which the peak torque/hp are made look a little early compare to factory specs at 4100/6400 though.
Old Aug 10, 2015 | 04:21 AM
swfla's Avatar
swfla
Well, seems there are several opinions. Who's an engineer here? Let's get an absolute answer converting metric figures to American HP. I tried to Google to this morning and didn't find any clear answer. Need more coffee
Old Aug 10, 2015 | 07:56 AM
Vvman's Avatar
Vvman
I am no engineer nor mathematician but the hp formula is really
HP = (rpm x torque) / 5252 where torque unit is in lb/ft.
Converting torque in lb/ft to nm, just multiply by 1.3558 and you will have
HP = (rpm x [torque x 1.3558]) / 5252 x 1.3558 where torque unit is in nm while HP is fixed.
Hence, HP = (rpm x torque in nm) / 7121
With reference to the dyno chart above, at 5200 rpm (pretty close to 5252 rpm) on the horizontal axis, the corresponding torque chart shows an estimate 375 nm, hence we have
HP = (5200 x 375 nm) / 7121, giving approx. 273.8 hp.
This corresponds roughly to the same figure. (ie 273.8 hp) on the HP curve above. Pretty spot on to the intersection we would expect at 5252 rpm.
Oliver Enterprises
Jun 10, 2025 11:08 AM
ericgarvic
Dec 20, 2016 10:14 PM
sam12345
Mar 13, 2013 12:04 AM
BUSTN
Oct 7, 2007 08:59 PM
BiGLeX 400
12
Apr 15, 2007 05:41 PM
