LS remote start install DIY
Old Sep 28, 2015 | 05:34 PM
  #181
vinniesabo's Avatar
vinniesabo
Originally Posted by roadfrog
This is all very tempting and I'm ready to pull the trigger. I'm good with wiring etc (I installed and did a DIY on the Nav bypass kit). My only concern is with the DBALL programming.....your post seems to hint that it may be fairly involved (?). Is it? When I look at the diagrams from Xpress, it seems straightforward....but is it?
GREAT write-up by the way!
Yes, it's definitely worth it.
Old Oct 20, 2015 | 12:53 PM
  #182
My1998LS40's Avatar
My1998LS40
I have the 2013 model and Bestbuy installer said that the FLCAN is not available. Instead idata has the ADS-AL-CA module for it. They want $250 for it installed. I looked and it only cost $50 online for the unit. If somehow I can get it flashed, I'd do the install myself.
Shibumi1: wonder if you can get me a module and have it flashed? I'll pay for it of course. Or if you know anyone would flash it, it would be greatly appreciated.
Old Oct 20, 2015 | 08:47 PM
  #183
Shibumi1's Avatar
Shibumi1
Fyi there's still no cost effective way to do takeover... short of bypassing all of the door triggers....
Old Feb 24, 2016 | 01:00 PM
  #184
Kuhan's Avatar
Kuhan
Never mind ...I just bought on EBay for 59 bucks and pre-flashed for my vehicle. GREAT deal!!
http://www.ebay.com/itm/301085632013...84.m1497.l2648
Looking forward to installing it...I get it on Tuesday.
Thank you for the link!
I just ordered it from this seller. I'm thinking of getting a Smart Start DSM 250 or DSM 350.
Old Feb 25, 2016 | 01:16 AM
  #185
pompecukor's Avatar
pompecukor
Hi all, I am not sure I understand the compatibility listings here
What I want to find out is if this is applicable (as in will funtion) with a 2008 LS600hL.
On the compatibility list I see "RSR" from 2009 onwards, and only "standard application" for 2008.
This according to the legends.
So what is standard application.
Can anyone confirm this would work with 2008?
Thank you.
Old Feb 25, 2016 | 04:36 AM
  #186
Kuhan's Avatar
Kuhan
Thank you.
What it means is that you will need an additional device for remote start like Viper, Python, etc since your year doesn't come with remote start ready feature.
Old Feb 25, 2016 | 04:43 AM
  #187
pompecukor's Avatar
pompecukor
Hi,
Thank you.
Since then I found another (more official looking) site for the system. Here is seems it does remote start. I don't see a mention of the Viper or Python that you mentioned. Where can I confirm about this and know what exact devices that I would need to get.
http://www.xpresskit.com/VehicleComp...9&ps=1&s=0&c=0
Best ragards
Alex
EDIT: Also what makes me more confused with regards to what you wrote is that is I do select a firmware (from the dropdown menu) at the original link I aksed about . To be precise the TL3 3.14 Firmware. Then it shows 2008 LS600h as RSR. So are you definite about what you wrote? That is does need and extra unite apart from the DBALL2 kit?
Old Feb 26, 2016 | 07:12 AM
  #188
johnnyg66's Avatar
johnnyg66
Question. Who has installed the smart start system to a Dball2? Is it any more involved or does it simply plug and play into the dball2?
My searching has not really answered this yet?
Old Mar 4, 2016 | 03:36 PM
  #189
johnnyg66's Avatar
johnnyg66
Well installed it today. Went smooth. Remote start works on key fob. Just have to activate the smart start.
Old Mar 4, 2016 | 07:51 PM
  #190
Shibumi1's Avatar
Shibumi1
I'd contact a Viper dealer in your area.... DO NOT PLUG IN THE SMART START if the dball2 has power!!!! it will fry the dball2... unplug power (blue plug) then make sure to ground the gray wire from the smart start module.. then u can plug it into the dball2... then power the dball2 back up.. making sure the car is in clear view of the sky.. then all a dealer would need is the air i.d. of the unit to run a test an activate the unit
Old Mar 4, 2016 | 08:31 PM
  #191
My1998LS40's Avatar
My1998LS40
Anyone with a 2013 and up with remote start installed? I couldn't get mine done anywhere.
Old May 21, 2016 | 01:02 PM
  #192
vipdjason's Avatar
vipdjason
I have a 2013 and couldn't get mine to work. I did everything listed. maybe I didn't flash it correctly
Old May 21, 2016 | 08:54 PM
  #193
comotiger's Avatar
comotiger
I have remote start on my 2014. It was installed by the dealer on the new car for the first owner. I am surprised a Lexus dealer cannot install one.
Old May 22, 2016 | 07:59 AM
  #194
roadfrog's Avatar
roadfrog
Here's what I've found. Many average car audio shops shy away from anything like BMW, MB or Lexus. They're afraid of messing up a computer, module, etc. On my wifes X5, I had to find a high end specialty shop in Vancouver to install her remote start. Nobody else would touch it. For her CT200, I had less of an issue, and did find a local shop to do hers.
If all else fails, a dealer will do it. Albeit, at double the price probably..
Old May 22, 2016 | 06:17 PM
  #195
My1998LS40's Avatar
My1998LS40
I went to the dealer and they couldn't get it done on both my LS460 and IS250. Both are F-Sport models. At first, they tried to install it on my IS and didn't work. Then, they said it's not compatible.
