LS remote start install DIY
#241
So, I pulled the cover of today, It didn't look like the colors lined up with the paper, after about an hour looking over it, I gave up. Maybe it's just my 46 year old eyes. Anyone one in CT (eastern) willing to install this for me ? Say $40 or so ?
My kit is pre-programmed for my LS460 and I even have the red T-taps, with even the plastic tools to pop the covers off.
If no one here can help, I figure I'll drop by a car stereo installer to drop it in..
regarding pin numbers. 46 yo? I'll be 77 in October, LOL! Have a multimeter. Looks like you are installing one to use your OEM fob? Pushing lock button 3 times.
For this some cars have a wiring harness premade just plug them in to install it. I don't see any antenna hook up.
#242
Personally I am a fan of iDATA link and/or EVO stuffs. Last one I did was on 2015 RX450h. Make sure you are looking at right connector and orient the pin correctly
The last question is on the DG connector larger black wire, will the red T-tap fit on it, or do I need a different one ? Like a blue one
#243
Can I ask another question... As it's hard for me to get into that spot to do this. Can I unplug from the ECU to install these T-TAPS then put it back together. Should I unplug the battery when I attempt this (removing plugs from the ECU) ?
Cant see why I am having such a hard time with this, it looks simple but, I just cant get my hands in there to do it, Unplugging stuff to attach would seem to make it easy.
Then the last question the BLACK wire on the DG connector, it's larger than the other cables, will the RED T-TAP fit, or should I find another size not to damage the cable ?
#244
Will the new DB3 module work the exact same as with OP's DBall 2 module? Is there a plug and play harness that makes the install easier as in not having to splice wires manually?
#245
So,I tried this today (been afraid to do it and because my fingers are big so getting that T-TAP on those little wires I could not do). I pulled the battery on my car (dam radio reseets !), and one by one, I removed the plugs from the computer. mapped out each spot, used red T-taps and went one by one (this made it VERY EASY to do). The BLACK/power cable was the hardest, I had to cut the cover, step by step till I exposed the wire, then too the 2 connectors that needed to be oh power, dropped a bit of sodder and about 4 layers of electrical tape. I wish I had a T-tap for the power wire (would of gone much quicker). The ground was easy, there was a metal frame with a screw in it, losened it up, put it on there, tighted it up. Took me about an hour, but, I was going slow.
Now remote start works, Thanks to this thread... finally it's working !
#247
anyone in Dallas Fort Worth know how to install this
Anyone in the Dallas Fort Worth area know how to install this I have a 2009 ls460 awd vase non ML system I have the dball3 pre flashed from eBay
#248
I called a number of shops here in Houston. I asked if I could get them to install the dball until. Places wanted 250 to 350 with me bringing the unit. One asked for 600 for the unit plus install.
I gave up on remote start until Best buy offered the Compustar system for 199 installed. I ordered that and it arrives in a few days.
#249
$250-300 ? WOW, ebay $1.00 for the red t-clips.... it's not that hard to do. In fact, compared to others said on here, Pulling the battery and pulling the plugs from the computer one by one is easy to do...
I mean I suck at wiring in cars, I never would even do a car stereo on my older cars but, this was not that bad at all. only 5 wires to connect.
I picked up the ebay one... I didn't want to do it myself, so I tried to call 3-4 places. They all would not touch it for legal reasons.
#250
Instruction is on their web site. Their tech support is very good as well as Compustar tech support who are very friendly. Make sure you stay away from big Yellow cable under dash near steering column which is for air bag. If you are not sure, disconnect battery for the safety. If you make mistake, it can blow ECU($$$ headache)
Some working at the shops usually moonlight at their home charging less $$ for the job. If you don't want to try yourself. Good luck.
#252
The difference is, with 3rd party kits, you need another remote on your keychain. This one you just use the factory remote.
#253
start the engine every so many hours and make it run for xx minutes and shut down. Don't need to plug in block heater. Or can make the engine start at certain time.
#254
Have you installed new RF kit(antenna kit) with it?
#255
on first try, it'll try 2 more times. Having a 2 way remote is very good. When command is carried out blue LED, when failed red LED flashes as a return signal. Now
we can install a kit for Bimmers too. It just costs more than for other cars. Installing one on M2 cost little over 1G by DIY.
