DIY control arm fix
I have viewed the info about fuel rails and valve springs- those have been done. I can see the bushings in the control arms cracking, but have no bad manners yet. So...
Has anyone posted a DIY on the control arms?
Does anyone have a way to get the service manual?
Thanks!
PS I am buying an 07 LS460 with 27K miles
Thanks!
wpm66, I'm going to be lazy here, but if you do a search in this forum for "control arms" you should bring up several threads on this topic.
Black Moon, there were recalls for the fuel rail, valve springs and idler pulley on the 2007 models. There is no expiration date for these items. Check the service history of your vehicle for these items to see if they were done. If they weren't you can have a dealer do them at no cost to you.
To the OP - be sure to get a Lexus Platinum extended warranty. There are other cheaper sources out there than the local Dealer - do a search.
The control arm replacement is covered by the Platinum warranty - a $3K repair.
Thanks for the input so far. I have done a search on control arms but as yet have not found a service manual or a DIY article on the issue.
Has anyone tried the replacement bushings (not the whole control arm) that someone said were on ebay?
I haven't tried it myself but since the original is so crappy it break up that quickly I would give aftermarket a shot if. Need to replace them (and for that price you can't really go wrong). I would just get the whole arm for a few bucks more i save all the troubles since you have to press out the old bushing and press the new one on. Unless you are a mechanic and have a press and all ...
sktn77a
May 30, 2019 05:39 PM
evenparr24
Sep 30, 2011 05:07 PM
