HELP!!! Interior dome light trouble...
Old Oct 31, 2012 | 09:55 PM
PhatDad's Avatar
PhatDad
Default HELP!!! Interior dome light trouble...
Well, I got my new interior LED lights from the CJITTY thread and went to install. All good up front, bright as h#ll!!! Went to put in rear dome, which is usually easier then the front. Plugged everything in... nothing. Played with it for a minute... nothing. Put original LED back in, now that one doesn't work. Spot lights on either side of the dome work fine.
Any ideas? I checked the fuse box on the drivers side, all good.
Old Oct 31, 2012 | 10:12 PM
CJITTY's Avatar
CJITTY
Do you have the polarity correct? Silly question but that got me once for a minute..just switch the black connection 180°..also close all doors to reset the battery saver feature. The rear dome only comes on with back doors. Start the car and try it that way..those LEDs draw no power really so can't see a fuse issue
Old Nov 1, 2012 | 11:19 AM
lbintab's Avatar
lbintab
The rear ones come on when you unlock the car with the key as well. I got those led's too.
Old Nov 1, 2012 | 01:21 PM
CJITTY's Avatar
CJITTY
Guess I haven't noticed the rears during the unlock..probably because i have 72 LEDs glaring down from the front and I'm blind and don't notice lol
Old Feb 11, 2013 | 10:01 PM
hwdp86's Avatar
hwdp86
I just wondering cuz i got same problem have you fix that if yes plz let me know how. THX
Old Feb 12, 2013 | 12:13 AM
adamls2's Avatar
adamls2
Try flipping it around like mentioned above...I had to do that to make sure it worked.
Old Feb 12, 2013 | 01:52 PM
CJITTY's Avatar
CJITTY
Yes..reverse the black pigtail connector..try that..also my rear dome will not come on unless I open a rear door. Even on unlock fob press, it only seems to turn on the front dome
Old Feb 13, 2013 | 12:48 PM
RandyV's Avatar
RandyV
Did the OP ever get his fixed?
Post a follow-up fer gawd's sake!
Old Feb 18, 2013 | 04:25 PM
hwdp86's Avatar
hwdp86
Default still doesn't work
i tried flipping them out it still didn't work i tried different bulbs but there is still no power fusses are ok. Is there anyway to reset this or you think there might be a different problem?
Old Feb 18, 2013 | 04:42 PM
CJITTY's Avatar
CJITTY
Try a diff location..does a std bulb work
Old Feb 18, 2013 | 05:32 PM
SBlexus's Avatar
SBlexus
This sounds stupid but make sure to turn your door/ dome switch to the ON position.
Old Feb 20, 2013 | 05:53 AM
hwdp86's Avatar
hwdp86
Yeah i tried that b4 and now again just to make sure. I cant belive led burned it its got to be something else. I dont want to go to the service cuz they will charge me crazy money for that bs. But thanks guys for trying!
Old Feb 20, 2013 | 05:56 AM
hwdp86's Avatar
hwdp86
I tried diffrent locations, diffrent bulbs, regular bulbs, on/off still front doesnt work. Back is fine . I have no idea.
Old Feb 20, 2013 | 07:45 AM
CJITTY's Avatar
CJITTY
time to check fuse box
Old Feb 28, 2013 | 03:30 PM
PhatDad's Avatar
PhatDad
Sorry guys for the delay but I don't have any good news. I could not get the rear dome to work. Tried flipping the bulb, etc. Nothing. I kind of gave up. The front dome is so bright that I'm just going with that for now. Maybe I'll stick the stock bulbs back in and take it to the dealer and play dumb.
