Non Lexus battery replacement
Old Dec 19, 2025 | 07:55 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Originally Posted by Leadfoot6
In the Mitsubishi automotive forum that I moderate(primarily for my knowledge of the Australian built Mitsubishi Magna/Verada - sold in the USA as the Diamante)
it is possible for a search term result link to remain "alive" for more than a few minutes:
https://www.mitsubishi-forums.com/th...33#post-562933
(the above example goes back to February2025 and is still "alive", with plenty more of similar examples that I can point to from the Mitsubishi forum)
I would hope that CL Administrators will make some effort to make this, seemingly simple, procedure possible here as well.
Thank you.
As a moderator there I assume you know that the other community you mention runs on completely different forum software called xenforo (think Mac and PC). vbulletin is what CL uses and it simply doesn’t work that way and I have no way to change it. The search string is simply not saved long term here or on other vbulletin forums. It is not a “seemingly simple” solution, it’s just not the way vbulletin works..
i understand it is another few seconds of typing for you to describe the search criteria or even better give links to a couple of the best threads of the search results to help others and I, and I’m sure they would appreciate that.
if you want to discuss further let’s take it to pm and get this thread back on topic thanks.
jag0124
Jul 11, 2025 08:03 AM
Nooblex
Dec 20, 2024 12:13 PM
alextv
ES - 7th Gen (2019-2025)
Dec 7, 2023 10:32 AM
Dejan13
Nov 14, 2023 06:02 AM
AJLex19
Aug 7, 2017 06:21 PM
