New Arnott Coil conversion?
I havent seen this ever before. Anyone tried it? Hopefully a better alternative to Strutmasters.
P/N: Arnott C-3418
https://arnott.mycarparts.com/items/C-3418
It's $655 on Rockauto https://www.rockauto.com/en/moreinfo...13000&jsn=1297
P/N: Arnott C-3418
Already on sale on Rockauto for $655. Seems too good to be true assuming they are not shotty like Strutmasters. At least they have the suspension light bypass which i dont need.
Low mile OEM sets aren’t that easy to find that you can just swap in. You will still likely need to buy new shocks and strut mounts to swap them into used OEM springs. People also don’t realize spring rates may vary and heights are different for 2007-2012 vs 2013-2017 when purchasing.
For me with the Ultra Lux package, I would likely need to rebuild an OEM set considering how hard it is to access the rear deck.
Neither Arnott or any other aftermarket air shocks can interface with Lexus control system. Considering this is a downgrade to standard shocks, there are other brands of shocks that members have used and posted their results on the forum. Time is the true test of a new product and Arnott doesn't meet that yet. I hope they are good. Do a search here for other time tested shocks.
All LS460 suspension hardware are compatible for all years. Just know that 2013-2017 stock ride height sits lower than 2007-2012.
then ultra lux package is not easy to disassemble
If you want OE control and function go OE.....Arnot is totally fine and they are well made but will not have CDC. Frankly it doesn't matter much on these as sport vs normal mode is still boat vs boat lol
We’re getting off topic. Arnott released a new coil spring product. Just wanted to know if anyone had experience with it. Seems like it’s too new for anyone to have used it yet.
Personally I would hope that it’s reliable irrespective trying to match OEM quality as long as it’s not bottoming out or being overly stiff.
And yes, for me there is no perceptible differences between normal and sport on the air ride.
I agree no difference with normal vs sport. My Fsport has sport+ that definitely firms up suspension, which I use on rough uneven roads & over speed bumps.
