Oil question please
Old Sep 22, 2023 | 04:35 PM
colfax's Avatar
colfax
Default Oil question please
Hello, I have a 2007 LS460 with around 166,000 miles
Up to now I have been using full synthetic 0-20 and this requires adding a quart around every 1300 miles or so
Should I stay with the 0-20 synthetic or change to what, 5-20,10-20, still all synthetic?
Please advise as I am no expert on this!
Thanks
Old Sep 22, 2023 | 05:53 PM
swfla's Avatar
swfla
There's a good chance that the piston rings have deposits and causing the oil consumption. There are professional treatments that are added to oil, run about 15 minutes and then an oil change. This can ungum the rings and allow them to stop oil consumption again. It's a ring issue that is known and the few hundred you spend may resolve your issue. Better to try and fix a problem than to change oil weight.
Old Sep 22, 2023 | 06:06 PM
Check the PCV, and if that's working I would pull the plugs and attempt to break the rings free using B12 left to soak 4 hours for every 90* of rotation.
When I picked up my 460 it burnt about as much as yours at first, I did the above and then drove it very hard to get everything to clear up. These engines need to be redlined here and there or you will lock up the rings.
Do not charge weight to anything other than 0w-20 or 0w-30 at max, and that's only if you are going to really get heat into it...
Old Sep 22, 2023 | 06:37 PM
Boykie's Avatar
Boykie
Oil change intervals?
Old Sep 23, 2023 | 02:02 AM
napamikey's Avatar
napamikey
My 2012 has 270k and does not lose a drop over 7500 miles. Leak?
Old Sep 23, 2023 | 06:54 AM
swfla's Avatar
swfla
Pulling spark plugs will tell you if oil is getting past the rings and burning it. If so, new plugs will probably be appropriate. Also, a bore scope can be inserted for a look inside. If you really want to know. If the valve cover gaskets are leaking there will be oil on the exterior of spark plugs. Multiple reasons to check the plugs.
Old Sep 24, 2023 | 07:19 AM
JohnnyC407's Avatar
JohnnyC407
Do not change the weight of your oil under any circumstances. Use the manufacturer's recommended weight. They spend millions of dollars refining the engine for a specific weight.
Have you tried a different synthetic? Mobil? Penzoil? Etc.
Are you using a high mileage oil? Those have additional detergents.
What's your oil change intervals?
What are you driving habits? In-town or highway?
I've had good luck with Marvel Mystery Oil as a cleaner. But you do have to change your oil afterwards.Run it around the block to circulate and then turn off. Doing that several times in a day. Then change the oil and filter.
Old Sep 24, 2023 | 07:46 AM
swfla's Avatar
swfla
What symptoms were relieved after using MM oil? Was it in Toyota/Lexus product with the low tension rings?
Old Sep 25, 2023 | 05:49 AM
JohnnyC407's Avatar
JohnnyC407
I've used it to clean pistons, stuck rings, sludge. It has chlorobenzenes and mineral spirits in it.
Old Sep 25, 2023 | 07:22 AM
swfla's Avatar
swfla
No symptoms? Sounds like great preventative use. I'd spend the extra money on shop supplied treatment for severe symptoms like the OP has. IMHO.
Old Sep 25, 2023 | 07:43 AM
JohnnyC407's Avatar
JohnnyC407
I did use this on my 4Runner and LS600 when I bought them, just to clean out the engine. But I don't have any issues otherwise.
I use Mobil1 high mileage on my cars and never had an issue changing at 5k miles. I've looked under the valve covers and they are clean and shiny.
daryll40
May 31, 2015 02:22 PM
SilvaIS350
Nov 7, 2009 08:55 AM
818sc400
May 21, 2008 07:51 PM
yo.
Jan 12, 2007 10:20 AM
Silver300gs
Jun 28, 2001 03:00 PM
