2003 LS 430 mark levinson problems?!? help
It's not a rattle-yer-neighbours-windows system but does give a pretty good reproduction of what was recorded and is plenty loud enough.
Speakers and the sub can normally be re-foamed if they are crackling. Sub can be replaced with a $50 Dayton-Audio one if needed.
If yours has no sound at all then amp repairs can be pricey, or you could grab a used amp off eBay for $200.
I like my system for Prog rock, Classic rock, and Thrash/Death Metal but everyone has a personal "sound" that they like.
my problem is I am not much of a "do IT yourself" person, probably can figure it out yet I do not have any tools...
If you're happy with what you have, I would just repair the woofer and continue on.
Your local Car Audio shop would probably replace your speakers for you but at a cost.
If you can find a mom-n-pop type place, they may even re-foam the speakers for you.
Tell them that the subwoofer is 8" and 16Ohm but I believe that you can get away with 8Ohm and many on here have.
If they replace speakers and woofer, there will almost certainly be a change in the sound of the system as the ML was a "reference" designed system where everything was supposedly designed to work together.
If they'd used quality rubber suspension for the speaker cones instead of crap foam that degrades over time, then the system would probably still be working perfectly.
That is what I would do in your situation.
It may be too late for you but I will throw this out- if your car has the rear sunshade, use it. My '05 subwoofer speaker shows no degradation or rattling after 15 years and the PO was religious about using the sunshade (and parking in a garage too helped I am sure). The theory is that It blocks light which degrades the foam,
'preciate your time...good look'n out...
I surely wasn't in the mood to pay $400 for a used replacement that will likely do the same thing shortly thereafter, especially considering the system is pretty "weak" if you're into music with a more emphasized low end. So I went about fixing it the cheap way.
Following this guide here, I went about removing the CD changer on the ML radio in place of a decent/mid-ranged head unit with 6 RCA Outs, picked up a $200 5-ch amp from Amazon, a cheap 8" subwoofer for $30ish and got all the other goodies (wiring kit etc). I went about tapping into the harness coming out of the ML amp to utilize the original wiring because I knew I wasn't going to push the system, I didn't want to replace the wires, and I planned on using the ML speakers until I had more money to get better door speakers later on.
While I'm not 100% satisfied with the redundant radio controls it was nice to have my sound back with a bit of an upgrade no less. Whole fix was about $350ish after everything was said and done.
I'll warn you though. Taking apart the back seat will be a tedious mess. It's very doable, its just a lot of work for a back seat.
