Need help figuring out diagnostic code for 2002 LS430
Old Apr 18, 2020 | 02:49 PM
ChiMade24's Avatar
ChiMade24
Default Need help figuring out diagnostic code for 2002 LS430
I just bought a 2002 Lexus LS430 for $4000 with 87k miles just got it yesterday there were no codes but today a code popped up as c1500 does anyone know what that code means and what the fix would be? I tried searching online for that code for a Lexus ands can't find any info
Old Apr 18, 2020 | 03:33 PM
02Legend's Avatar
02Legend
C1500 Transfer Case Contact Plate "B" Encoder Circuit Failure
I checked this on a couple of websites. I also use an Innova OBD 2 scanner and you can look the codes up on their website.
https://www.innova.com/home/dtc-library
Old Apr 18, 2020 | 04:13 PM
TriC's Avatar
TriC
Except an LS 430 doesn't have a transfer case.
To OP: are you sure about that code?
Old Apr 18, 2020 | 04:27 PM
02Legend's Avatar
02Legend
I thought about that, and posted anyway. Thanks for jumping in and saying something. A P1500 comes up as "starter signal circuit malfunction".
OP: Ignore my original post please.
Old Apr 18, 2020 | 04:33 PM
TriC's Avatar
TriC
Suggest initially clearing the code and checking that your battery connections are tight. If it comes back, check that fuses are secure.
Old Apr 18, 2020 | 04:56 PM
ChiMade24's Avatar
ChiMade24
Thanks I will definitely try that that's weird that c1500 popped up if there is no transfer plate though but that's definitely the code that popped up
Old Apr 18, 2020 | 05:07 PM
bradland's Avatar
bradland
How did you pull the code info? Any chance you're using a store-bought code reader claiming compatibility with multiple vehicle brands...?
Old Apr 18, 2020 | 05:10 PM
ChiMade24's Avatar
ChiMade24
Yes that's exactly what I'm using so i take it those are not accurate then huh?
Old Apr 18, 2020 | 05:26 PM
bradland's Avatar
bradland
I've never used one but I do remember other forum members pulling confusing codes with generic readers.
Old Apr 18, 2020 | 05:30 PM
ChiMade24's Avatar
ChiMade24
Hmm if it is reading the wrong code and it sounds like it is I think I'll just have it checked out to see if there is a problem I have noticed a weird noise below the passenger seat
Old Apr 20, 2020 | 11:46 AM
ChiMade24's Avatar
ChiMade24
You were right man it was throwing the wrong code the problem was an o2 sensor and wheel motion sensor also needed to get brakes, rotors, and a bearing done
Old Apr 22, 2020 | 07:56 AM
StanVanDam's Avatar
StanVanDam
If you are replacing your bearing due to a bad wheel speed reading, check your speed sensor cable first - those are known to fail on both front LH and front RH sides. Cheap and easy to replace.
Old Apr 22, 2020 | 07:58 AM
ChiMade24's Avatar
ChiMade24
Thanks for the info appreciate it!
Old Apr 27, 2020 | 01:46 PM
infojunky's Avatar
infojunky
For future use
https://www.clublexus.com/forums/ls-...for-ls430.html
A sado masochist chose the location of the O2 sensor connections.
murphy396
Nov 25, 2018 07:46 PM
hms09
Aug 20, 2013 06:25 AM
Hatchman
RX - 1st Gen (1999-2003)
Jul 14, 2010 04:13 AM
lvladcrazy
Suspension and Brakes
Jun 27, 2009 08:50 AM
VQT
Maintenance
Oct 15, 2007 06:41 PM
