Bluetooth & music streaming module
Old Aug 10, 2019 | 01:02 PM
ChinneeTee's Avatar
ChinneeTee
Default Bluetooth & music streaming module
I own a 2004 LS 430. Thru testing I’ve determined that my Bluetooth is dead or dying. I remember seeing a link in this forum for a unit that replaced the stereo receiver and the CD loading section of the center console with the unit that had music inputs, a small screen, a USB and an AM/FM receiver. I believe as well as a new Bluetooth and the ability to stream music (as well as plug-in). I have been unable to find it with the exception of that Chinese unit that replaces the whole system including the nav screen which I’m not going to do. The best alternative seems to be the Grom Audio unit that supplies Bluetooth for the phone and music streaming. It usually installs in the glove box and has a wired mic that you install in a position of your choice. Your steering wheel audio controls also continue to work. I’m about to have this done because my Bluetooth won’t connect, or stay connected or drops continuously with my Google Pixel 3XL. By using an aftermarket Bluetooth that plugs into the cigarette lighter I was able to determine that it is the car’s Bluetooth and not the phone that is the issue. Anybody else remember this link or have similar experiences or suggestions.
Old Aug 10, 2019 | 01:33 PM
Bsavage's Avatar
Bsavage
Bt 45 is plug and play for 04
https://www.amazon.com/USA-BT45-TOY-Bluetooth-Select-1998-2014/dp/B0178G5RRE/ref=mp_s_a_1_1?keywords=bt45toy&qid=1565469141&s=gateway&sr=8-1 https://www.amazon.com/USA-BT45-TOY-Bluetooth-Select-1998-2014/dp/B0178G5RRE/ref=mp_s_a_1_1?keywords=bt45toy&qid=1565469141&s=gateway&sr=8-1
Old Aug 12, 2019 | 05:57 AM
ChinneeTee's Avatar
ChinneeTee
Yeah, thanks, this is basically what the Grom Audio unit is & I have a dealer here in town. Looking for more robust options, thanks anyway
Old Aug 12, 2019 | 07:41 PM
Ellesse's Avatar
Ellesse
You're describing what sounds like someone installing an aftermarket radio in place of the cd loader, not an add-on unit, e.g.
https://www.clublexus.com/forums/ls-3rd-gen-2001-2006/809419-03-ls430-amp-bypass-stereo-install-w-pics.html
As mentioned, the bt45 is probably your most seamless option - takes about 15 minutes to install, is hidden in the dash, and gives you bluetooth and aux.
jasone36
Sep 16, 2018 11:12 AM
ABbirds
Jul 27, 2017 02:20 PM
abbyNormal
Feb 24, 2016 09:33 PM
Carnello
Apr 2, 2014 11:19 AM
urzh
GX - 1st Gen (2003-2009)
Dec 10, 2013 01:41 PM
