Cheap LED third brake light
Old Aug 2, 2019 | 07:15 PM
LexRex's Avatar
LexRex
Default Null
Go buy yourself a third brake light.
Old Aug 3, 2019 | 08:08 AM
kos's Avatar
kos
Looks good! I need to get better at my soldering haha. Any recommendations on a good solder kit? Weller I'm guessing?
Old Aug 3, 2019 | 08:30 AM
ebxgsxr's Avatar
ebxgsxr
looks good. but why not just go with an LED bulb in the housing?
Old Aug 3, 2019 | 09:28 AM
RA40's Avatar
RA40
Super Moderator
Looks good
Thanks for posting the part sources.
Old Aug 3, 2019 | 04:52 PM
Yamae's Avatar
Yamae
Originally Posted by LexRex
This will probably cause a "bulb out" error on 2001-03 cars. This mod is best for the 04-06 cars anyway, since it removes the lag between the LED tails and the incandescent 3rd brake light.
The "bulb out" error problem on 2001-03 cars can be corrected just changing the resistor R121 = 0.04Ω for 3rd brake light for those who are OK to do solderings and a part selection. The resistor is used in the “Multiplex Rear Junction Computer” which is located in the trunk. The resistance value can be calculated simply just using an Ohm's Law. You can find the detail here.
Old Aug 3, 2019 | 08:40 PM
ebxgsxr's Avatar
ebxgsxr
same things happened to me the 1st LED bulb i put in. it was bright at 1st, but then noticed one time i could barely see it. i ended up getting another brand and it has been great. but yours definitely turned out nice.
Old Aug 4, 2019 | 01:53 AM
HiloDB1's Avatar
HiloDB1
Did my own chasing 3rd brake light. You could probably do something similar without the chasing for cheaper but I think I spent less than $50 in material for the chasing setup.
https://photos.app.goo.gl/AkLvygCMoeu6cKkA8
Old Aug 4, 2019 | 10:54 AM
ebxgsxr's Avatar
ebxgsxr
now that is awesome too.
Old Aug 5, 2019 | 05:42 AM
ebxgsxr's Avatar
ebxgsxr
Do you remember where you got that bulb that worked well?
these are the ones that worked & you can see in the picture.
https://www.amazon.com/gp/product/B06XQWPKKX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B06XQWPKKX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
johnnylt
Aug 28, 2018 04:32 AM
Aristo722
May 13, 2016 02:10 AM
akash3230
Sep 6, 2011 12:43 PM
RX300Scott
RX - 1st Gen (1999-2003)
Jan 18, 2011 09:57 AM
triplecore
Nov 4, 2008 05:34 AM
