Fender help
Old Jun 30, 2019 | 08:35 PM
user 7082244255's Avatar
user 7082244255
Default Fender help
So I recently purchased my one owner 04 UL and as it is very clean inside the body is fairly good condition too but the fender could use some work, but I would like to purchase a whole new fender, does anyone know any reputable brands, for an oem fit painted or unpainted, thanks in advance, also does anyone know what this is on the trunk it has a wire running to the trunk liner towards backseat
Old Jun 30, 2019 | 09:17 PM
weldthedif's Avatar
weldthedif
I would not purchase aftermarket, i would look at junkyards to get a used fender. You might even get lucky and find a black one, black is a common color on the LS430
Old Jul 1, 2019 | 01:57 AM
BigBoomer's Avatar
BigBoomer
Looks like a GPS antenna, or maybe Satellite Radio.
As for the fender, is it not repairable?
It'll have to be pretty badly mangled to not be repairable.
Old Jul 1, 2019 | 04:28 AM
430's Avatar
430
It is the antenna for satellite radio. In 2004 to 2006, it was a dealer installed or "port" installed option, If you don't have or want SiriusXM, you can remove it. If you do want it, many have used other locations, such as inside the third brake light on the rear deck. If you search, you will find a lot of information on the topic.
Old Jul 1, 2019 | 09:48 AM
Bsavage's Avatar
Bsavage
Are you looking for a left or right side fender ? I would check offer up I’ve seen some fenders on there
Old Jul 2, 2019 | 03:41 PM
user 7082244255
The driver fender damage/whoever did the horrible body work pictured below
Old Jul 3, 2019 | 11:35 AM
StanVanDam's Avatar
StanVanDam
Looks like it was a rookie PDR (paintless dent repair) done with the back of a screwdriver by the previous owner. A professional/experienced PDR tech would have done a slightly better job. You should get some quotes from local PDR shops, maybe one of them can fix it up for a reasonable price. If you are dead set on getting a new panel, OEM obviously has the best form, fit, and finish. Your local Toyota/Lexus/insurance collision repair centre can quote you on the parts and labour involved.
Old Jul 3, 2019 | 12:53 PM
pmesfun's Avatar
pmesfun
Here is a used black fender not far from Chicago(from your post history). https://imageappky.car-part.com/imag...%23%2018I431#1
JCtx
RC F (2015-present)
Sep 20, 2015 11:57 AM
Sanddwich
Jul 3, 2014 03:29 PM
konaboi808
CL of Hawaii
Jul 2, 2012 06:40 PM
soaringsc3
Feb 13, 2009 01:24 PM
