AFS sensor
Old Feb 25, 2019 | 06:54 PM
Lzam's Avatar
Lzam
Unhappy AFS sensor
I replaced my afs sensor with a $30 dollar version from rockauto it didn't work so I guess I have to buy the $100 dollar one imagine that.
Old Feb 26, 2019 | 03:00 AM
warminwisc's Avatar
warminwisc
U have a pic of 100 dollar one
Old Feb 26, 2019 | 06:45 AM
rkw77080's Avatar
rkw77080
The LS430 height sensor is simply a potentiometer (also known as a rheostat) which acts a variable resistor. It is attached to the car's suspension, and is subjected to constant movement as you drive. As such, a cheap replacement will not last nearly as long as the OEM part. However, there should not be significant differences between the OEM part versus its knock-off counterpart when both are new. In other words, if your new $30 sensor does not work, the problem is likely caused by something else, and a $100 new sensor will not address the issue.
Old Feb 26, 2019 | 08:27 AM
ebxgsxr's Avatar
ebxgsxr
isn't there supposed to be a light on the dash when you hit the button? i hit mine and nothing happens. no light on the dash or anything.
Old Feb 26, 2019 | 08:47 AM
kos's Avatar
kos
This. ^^^
Try checking your fuses and see, there should be a light on the center/left side of dash that says AFS OFF when disabled.
Old Feb 27, 2019 | 04:28 PM
Lzam's Avatar
Lzam
The Dorman one on ebay. 924-755
Old Feb 27, 2019 | 04:30 PM
Lzam's Avatar
Lzam
It didn't flash continuously until I changed it out!
Old Feb 27, 2019 | 05:17 PM
rkw77080's Avatar
rkw77080
Did you keep the old sensor? If so, try reconnecting the old sensor and see if the "AFS OFF" light stop flashing. No need to uninstall the new sensor from the car, just move the electrical connector.
Marston
Oct 12, 2021 07:42 AM
Lzam
Mar 5, 2019 05:30 PM
sevilla1
Aug 28, 2017 02:38 PM
wildwheels
Jul 28, 2012 01:15 PM
