bulb change outside mirrors
Old Jun 14, 2018 | 05:25 AM
johnnylt's Avatar
johnnylt
Default bulb change outside mirrors
Hello Everyone,
What is the easiest quickest way to change the puddle light bulbs underneath the folding mirrors on the doors? Ive read tutorials about pulling the mirror off but im afraid of breaking the tabs that connect it back on .
Thank you
Old Jun 14, 2018 | 07:20 AM
VWTim's Avatar
VWTim
Originally Posted by johnnylt
Hello Everyone,
Thank you
That really is the safest way to get to the bulb. Remove the mirror, 5 screws to separate the housing, and it pops right out. There are other ways, but you're tempting a broken tab on the actual painted mirror housing and light housing.
I did my passenger the other night in 5 minutes.
Old Jun 14, 2018 | 08:01 AM
johnnylt's Avatar
johnnylt
Thanks for the reply , do you pop the mirror out then take out the 5 screws? also what size bulb ? 168
Old Jun 14, 2018 | 10:29 AM
VWTim's Avatar
VWTim
tilt the mirror all the way up, reach behind the glass and pull the bottom away from the housing. Once those tabs pop, you can lift the mirror up vertically and disengage the hook at the top. You'll disconnect 2 wire plugs on the back, then can set the mirror to the side.
There is 1 screw that holds the mirror adjuster in that is spring loaded, remove that, set the spring aside and pull that assy out. It'll click, but that's normal.
Then access the (4) perimeter screws around the housing.
It's either a 168/194. I changed to LED when I was in there, so not 100% positive on spec as those are usually interchangeable.
Old Jun 14, 2018 | 10:38 AM
StanVanDam's Avatar
StanVanDam
I carefully pried the puddle light covers out with an old credit card. Just follow the steps detailed in the multiple other threads on this forum, memorize where the tabs are, and don't rush it - be patient. Bulb size was listed in one of those previous threads, I don't think it's in the owners manual but I think 168 is correct. Get the highest lumen downward-aiming LEDs you can find - there is no current-checking system for these puddle lights, so you won't see any lamp failure messages in the combination meter.
Old Jun 15, 2018 | 05:07 AM
johnnylt's Avatar
johnnylt
STanVAn Dam, what do you mean you pried the light covers out with a credit card? you didn't remove the mirror? were the covers easy to put back in ?
thanks
Old Jun 15, 2018 | 06:45 AM
Romanova's Avatar
Romanova
thanks
Did you search? This has been beaten to death. https://www.clublexus.com/forums/ls-...nd-part-s.html post #5 has what you need.
Old Jun 15, 2018 | 07:21 AM
05ls430518's Avatar
05ls430518
Grab two spackle knives and carefully shimmy the housing out from underneath the mirror, worst case scenario you break something and you have to buy 1 or two mirrors hahaha.
Old Jun 16, 2018 | 11:18 AM
Fojo's Avatar
Fojo
i broke one of my mirrors while trying to pry it out from the bottom. what you need to do face the mirror as far up as possible and look underneath about a-2 inches from either side on the bottom are the tabs. use a flathead to stick up to the tab and wtist it and it will gently pry them lose. then remove the 4 screws from behind the mirror on the housing. then you can separate the housing and take the lens out etc. when reinstalling put some silicone grease or something on the tabs and make sure you press on the outside of the mirror EXATLY where the tabs are when pushing in. again, otherwise you will crack it. once you do one, then the other will take 5 mins
** i wouldnt shimmy the housing out, that's asking to break somehting. I tried and chickened out. taking the mirror out is less invasive.
Old Jun 16, 2018 | 03:13 PM
johnnylt's Avatar
johnnylt
I think I’m going to leave the bulbs burnt out too much of a risk either breaking the mirror or cracking plastic lense getting it out too risky for a stupid light
have to admit will miss the lights
krnboy817
15
Jan 17, 2021 07:01 AM
mrsardar
Feb 25, 2018 11:57 PM
bello46
RX - 3rd Gen (2010-2015)
Oct 27, 2017 01:24 PM
LiLS
IS F (2008-2014)
Mar 17, 2014 03:53 PM
is.project
Jul 18, 2007 09:55 PM
