Replacing mirror turn signal bulb
Old Oct 26, 2017 | 03:05 PM
bello46's Avatar
bello46
Default Replacing mirror turn signal bulb
The turn signal bulb on the passenger side stopped working, I was wondering if anyone knows what size bulb I need and how I would go about disassembling the mirror.
I found a post about tilting the mirror all the way down and trying to pull it off. I gave it a try and couldn't get it off. Maybe I'm not using enough force? I'm a little bit concerned about breaking the mirror or any components inside.
Thanks for the help!
Old Oct 27, 2017 | 01:24 PM
Droid13's Avatar
Droid13
Check out the "Replace Puddle Lamps" in the DIY sticky thread, there's a video showing the mirror disassembly. The mirror is just a friction fit, but yes, it can be a tight fit and sound horrible coming off. If I recall, when I changed my puddle lamps I slowly worked the mirror from several sides and eventually it came out. The video makes it look easy, but I think its a bit more effort than that typically.
johnnylt
Jun 16, 2018 03:13 PM
mrsardar
Feb 25, 2018 11:57 PM
xRYD3Rx
Sep 5, 2014 12:24 PM
LiLS
IS F (2008-2014)
Mar 17, 2014 03:53 PM
messysc
Jul 31, 2001 09:38 PM
