Door speaker replacement?
Old Mar 6, 2018 | 01:13 PM
Robles84's Avatar
Robles84
Default Door speaker replacement?
Need help
what would be better to install with my oem mark levinston amp w navi
6.5 8omh
or 6.5 2way 4ohm
and what watts range sound I stay in to not blow my amp
Old Mar 6, 2018 | 01:28 PM
05ls430518's Avatar
05ls430518
Originally Posted by Robles84
Need help
6.5 8omh
or 6.5 2way 4ohm
Beatsonic kit with new headunit amp wiring then you can do whatever speakers work with the amp you chosen.
Or get 8ohm speakers which match the ml amp
Old Mar 6, 2018 | 06:26 PM
WindyCity1's Avatar
WindyCity1
I just did this. I replaced all 4 door speakers with 6.5" speakers rated @ 8ohms.
It sounds much better.
Old Mar 6, 2018 | 09:42 PM
tallcaguy's Avatar
tallcaguy
Brand? Cost?
Old Mar 7, 2018 | 05:02 AM
WindyCity1's Avatar
WindyCity1
Originally Posted by tallcaguy
Brand? Cost?
I used the
Skar speakers Skar speakers
that cost $20 each. I debated re-foaming the door speakers (I successfully re-foamed the subwoofer) but when I pulled the speakers I decided I'd just go new.
Old Mar 7, 2018 | 07:10 AM
caverman's Avatar
caverman
I used the Skar speakers that cost $20 each. I debated re-foaming the door speakers (I successfully re-foamed the subwoofer) but when I pulled the speakers I decided I'd just go new.
Good to know. Getting in on this thread in case I need to do the same in the future.
Old Mar 7, 2018 | 08:08 PM
RRocket's Avatar
RRocket
No fitment issues? Any issues screwing them into the housing?
Are the OEM speakers 4 or 8ohm?
Old Mar 8, 2018 | 11:37 AM
WindyCity1's Avatar
WindyCity1
No issues. The screw holes lined up perfectly.
My OEM speakers were 8 ohm. I measured them first to make sure.
Old Mar 8, 2018 | 01:08 PM
Robles84's Avatar
Robles84
That good to know... how many watts are your speakers that you installed? And I was thinking about swapping out my sub also.
I had a kicker 10" l7 but I blew it out. Amp has to much power lol. So my options are get 2 l7s or a jl audio w7 or replace the oem sub with a kicker comp or a jl audio w3 and run a low wattage amp with it
Old Mar 9, 2018 | 10:53 PM
Robles84's Avatar
Robles84
which speaker was it that you installed?
SrWilliams
Jul 13, 2014 06:22 PM
vietpr1nce
Jan 25, 2011 06:44 AM
SuPeRGoOk
Oct 14, 2010 08:09 PM
KKRlexus
May 9, 2008 01:52 PM
