"Height High" warning after suspension conversion
Old Nov 23, 2017 | 01:49 PM
Maxe's Avatar
Maxe
Default "Height High" warning after suspension conversion
Hi everyone!
I'm from Ukraine so sorry for my english in advance.
I just got myself a 2004 LS 430 which had an air suspension before but eventually had a conversion to shocks/springs.
Everything seems great, but on the dash i constantly have a "height high" warning accompanied by a red warning triangle.
The fuse for the air compressor was removed, however, the damn warning still stays on..
I've tried to study many local and foreign forums but never ended with finding the answers
Is there any way of fixing this issue because it's getting really annoying
Thank you for your help and answers!
Old Nov 23, 2017 | 03:28 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Assume you verified the correct fuse? Couple troubleshooting tips in this thread if you haven't read
https://www.clublexus.com/forums/ls-...ml#post7351756
Old Nov 24, 2017 | 10:07 AM
nc356's Avatar
nc356
The "height Hi" warning may have nothing to do with the suspension conversion.
Check the threads regarding level sensor failures.
Can you easily check your trouble codes? A code will direct you to the level sensor that is malfunctioning.
Sensor are easily repaired/ replaced with aftermarket sensors from eBay or Amazon.
Old Nov 30, 2017 | 03:15 PM
Maxe's Avatar
Maxe
Thank you for your answers. So I've been trying to win this problem, but i need your help guys! I've checked if the correct fuse was taken out and yes, it was the correct one. Then i've tryed to adjust the height sensors, however, nothing happened diagnosis is saying that there are circuit problems on all of the height sensors, looks like someone with no conversion skills did that and i believe unplugged something that should not have been touched. The problem is i do not know were to start from. Does anybody know which fuse is responsable for height sensors? Or maybe there is a seperate relay or module that control these sensors? All sensors are on their places, plugged in but looks like they are deenergized because somebody did something wrong. I really need help! Thank you in advance..
Old Dec 1, 2017 | 06:17 AM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
Hopefully we can find the answer soon as I've had the same problem on mine for years and it drives me crazy.
Old Dec 1, 2017 | 06:28 AM
Maxe's Avatar
Maxe
Ok man i've got some good news! The problem is solved! So i've taken out the air compressor fuse in the driver side fusebox (on the interior) and then got the afs warning light, but the height hi went off. At this point i didn't stop and studied the LS's electronic diagram and found out that in the passengers side we also have a fuse called h lp lvl which is responsible for headlight auto adjustment (this is the only reason why we have to keep the height sensors after the conversion)
Soooo....
I've taken out that fuse (h lp lvl) and THANK GOD all of the warning messages went away and now i have a clear dash)
The only drawback is that the headlamps do not have auto height adjustment (which i personally think is useless as crap).
After all the work done, i adjusted the headlamps light manually using special equipment to make sure that it will not blind anybody on the road.
So what we have in conclusion:
-No warning lights on the dash
-No more messing around with the height level sensors which are expensive to fix if they fail (you can just throw them away)
-Manual adjustment made the headlights light properly, just imagine you have an ordinary camry with factory hids with no auto-leveling, this is not a problem
Drawbacks
-Auto light height leveling is inactive (i find it useless anyway, after manual adjustment nobody high-beamed me for blinding)
What to do after conversion from air to springs:
-Take out the fuse under the hood fusebox that is responsible for air compresoor
-Take out the fuse in the driver footwell fusebox that is responsible for air compressor
-Take out the "H lp lvl" fuse in the passenger footwell fuse that is responsible for headlight leveling
-Manually adjust the headlights with special equipment
-Done
I'm happy as **** hope this will be usefull to somebody
Old Dec 1, 2017 | 04:16 PM
rkw77080's Avatar
rkw77080
Check out the link below...
https://www.americanairsuspension.co...on-p/td14f.htm
They claimed to have an easy way to disable the height warning.
Old Dec 15, 2017 | 12:11 PM
TTBomB's Avatar
TTBomB
Anyone here run the American Air Suspension conversion?
Thoughts?
Old Nov 30, 2022 | 08:23 PM
Frankg2's Avatar
Frankg2
Found this YT video which shows how to disable the ride height computer, eliminating the Height Hi warning without disabling headlight leveling. I haven't tried it yet.. will update this after I do with effort and success info.
Old Nov 9, 2024 | 09:13 AM
GregE34's Avatar
GregE34
https://www.youtube.com/watch?v=XzBLQTmjY1I
Did a coil spring conversion on my 2005 this week. Pulled the suspension fuse under the hood and got the height hi and red triangle on the dash. Air suspension controller on the later cars is on the driver’s side under the steering column, not behind the glove box. Pulled the middle plug (as well as the other two) and still had the height hi and blinking AFS. Ended up just pulling the 20 amp air suspension fuse in the driver’s kick panel and the AFS fuse in the passenger’s kick panel.
OMEGX460
GX - 2nd Gen (2010-2023)
83
Jun 26, 2024 03:51 AM
jmscott
Apr 27, 2022 11:20 AM
hadris
Nov 14, 2016 10:36 AM
Zeke21
Apr 27, 2015 06:31 PM
ChantalB79
Jan 26, 2012 02:58 PM
