Audiocontrol lc2i question
Old Jul 15, 2017 | 04:24 PM
Robles84's Avatar
Robles84
Default Audiocontrol lc2i question
So I'm trying to install my sub set up the right way and bought this audio control line out converter.. It's rates at 400watts. But my amp is at 900 watts. Will this line out converter hold up? I will be pulling from the rear own sub power
Old Jul 15, 2017 | 06:10 PM
NL5's Avatar
NL5
I assume the amp you are adding after the conversion is 900 watts. In that case the wattage of your amp has absolutely nothing to do with the rating. That's input wattage from the factory amp which I believe is about 60 watts. You should be more than fine. I am using a cheap PAC converter without any problems. My subs are about as loud as they can be with the factory amp running the door speakers.
Old Jul 16, 2017 | 06:16 AM
Robles84's Avatar
Robles84
Any suggestions for installation? My friend and I both never installed one before
Old Jul 16, 2017 | 06:21 AM
Robles84's Avatar
Robles84
Here is my set up....needs to be cleaned up still
Rockford Fosgate T10001 bd 1-Channel which is way under rated as most people know and my 2ohm dual voice coil 10in kicker
Robles84
May 18, 2017 05:32 PM
RXRider13
May 15, 2014 04:46 PM
bezee
Aug 7, 2005 06:23 PM
Dx3
Nov 28, 2004 04:42 PM
CoreY2K1
Aug 23, 2001 03:49 PM
