Key wont turn ??
Old Apr 9, 2017 | 11:59 AM
jimisbell's Avatar
jimisbell
Default Key wont turn ??
1) This my first week with the 2004 LS-430. I insert the "key"and try to turn it clockwise and it presses in, steering wheel adjusts, it goes part way but wont go all the way to on. A message says check s/t. Does s/t stand for ****** ? After several tries, 3 to 10 tries, it magically turns !!! What is the problem?
2) I cannot change the battery in the fob? Seems silly for this to be a dealer option? Cant I do it? and how?
Old Apr 9, 2017 | 12:14 PM
Htony's Avatar
Htony
1) Steering/Transmission? I always put my foot on brake, tranny in neutral, steering in center position to start the car.
2) Fob abattery, you ahve to split open it to get access to battery. You will find Youtube demo. showing how.
Old Apr 9, 2017 | 12:38 PM
jimisbell's Avatar
jimisbell
OK, the tranny needs to be in Neutral? I have been trying and occasionally succeeding in Park?And the steering needs to be"centered" What is centered? Do I need to get out and make sure which turn I am on?
Old Apr 9, 2017 | 12:53 PM
swegyptian's Avatar
swegyptian
Just wiggle the steering wheel a little bit left and right, that's caused a problem a few times for me.
Old Apr 9, 2017 | 01:19 PM
jimisbell's Avatar
jimisbell
Thanks, that would seem to explain the randomness of the key working.
Old Apr 9, 2017 | 02:06 PM
rkw77080's Avatar
rkw77080
Yep! That's what the Owner's Manual says too...
Old Apr 9, 2017 | 03:44 PM
Htony's Avatar
Htony
Sorry I meant parking. Brake pedal, tranny in park, steering wheel turned too much either side will jam the key in the lok cylinder.(already jiggling steering was mentioned)
These 3 are elctrically(by spostion siwtch) or mechanically linked for safety.
Old Apr 10, 2017 | 02:43 PM
LS430inDE.'s Avatar
LS430inDE.
Looks like you got 1 answer for the key not turning. If the steering wheel isn't centered, you might need to jiggle it a little bit.
Your second issue was the battery for the key fob. You do not need to take it to the dealer. You can easily do this yourself. You simply need a small flat blade screwdriver, a new CR2032 battery, and about 3 minutes! (I'll spare you the step by step written details, but the link is a good YT video how to change the battery.)
The creator of the video said something that was wrong though. It doesn't affect you, but thought it was interesting----around the :15 second mark, they mistakenly called the keyfob a TWO button keyfob, but it's actually THREE. Many people don't notice the very bottom button is for the trunk release!
Hope this helps you out! PLEASE NOTE THE ORIENTATION OF THE OLD BATTERY! IT WILL LIKELY FALL OUT SO BE CAREFUL! One thing the creator of this YT video did NOT do is show the orientation/polarity of the battery!!! WTF? Also, when you think it's replaced properly, do NOT place the end cap on. You should TEST to ensure the polarity of the battery is correct! To test, simply push any of the buttons and ensure the red LED lights up on the keyfob. (Don't worry if you install the battery backwards, nothing will be damaged)....
Old Apr 10, 2017 | 06:40 PM
jimisbell's Avatar
jimisbell
yeah, I got the batts changed in two out of three fobs. Broke the first one trying to figure it out. Just got pissed and laid into it. Felt really good to destroy it...
And the steering wheel was the problem....seems like every time I tried to insert the key I had to turn the wheel to find the hole. Now I know I need to turn it back!!!!
Old Apr 10, 2017 | 08:45 PM
Gronemus's Avatar
Gronemus
Jim, does your LS have the SmartAccess option? If it does, you don't need to insert the key to start the car. Just turn the ignition switch when you get in the car...
Old Apr 11, 2017 | 04:46 AM
Johnhav430's Avatar
Johnhav430
I believe it's one in the same, meaning, we don't have a push to start button, we still twist a key like switch, and it is locked if there is pressure on the lock mechanism, just as an old car with a metal key. I'd like to know if this issue, is simply pressure on the lock mechanism (age old issue where the pressure needs to be relieved), or an intermittent failure of the electric lock (the latter was a serious BMW problem around 2006, expensive to fix, and also causes the vehicle to be inoperable). Again, I don't even think my 2007 BMW has any lock whatsoever, because it was a theft device way back when, but is unnecessary today...
Old Apr 11, 2017 | 07:19 AM
jimisbell's Avatar
jimisbell
I dont know. There is a little red light to the left f the steering wheel with a label "smart" ??
ChinneeTee
Jan 17, 2015 01:49 PM
shivett
Mar 29, 2010 09:09 AM
eli300
Jul 7, 2007 12:49 PM
jerrygrier
Dec 4, 2005 08:27 AM
ShowGSLuVv
Jun 16, 2002 08:51 PM
