Ipod integration question
Old Apr 2, 2013 | 04:00 PM
Anniehow's Avatar
Anniehow
Default Ipod integration question
I'm a new Lexus owner, and I love my Car but I have a stereo question.
I have a 2005 LS-430
When I bought that car I added Sirius Satellite radio with SSC1 tuner. When I installed it I asked about adding ipod integration and the installer said I would be unable to do so because there were no more opening in the back of the radio.
I have since found this item that said it can be added if the satellite radio is factory installed.
http://www.pie.net/test2.html?vid=1&...39&modelId=678
Although it is not factory installed I was hoping I would be able to ad this for my Ipod. Does anyone that know about stereo equipment know if this would work?
I appreciate any help I could get,
Thanks in advance.
Gisele
Old Apr 2, 2013 | 04:47 PM
ayonnebay's Avatar
ayonnebay
I have added a VaisTech SL2s Sirius adapter with a Sirius SIR-PAN1 (not SSC1) tuner to my 04 LS430. I also have a VaisTech SL2i iPod adapter.
When I added the Sirius SL2s adapter, I thought I'd have to give up the SL2i iPod adapter I already had in the car, but Vaistech advised that the two units can be daisy-chained together. I did that and now have use of both ...
You may be able to do the same, but I don't know which brand Sirius adapter you have with your SSC1.
Note: Each adapter must be programmed individually. That is, first install & program the Sirius adapter setup. Then, unplug that setup. Now install & program the iPod adapter setup. Once each is programmed to work individually, the two can be just plugged together in daisy-chain fashion, and all should work fine. Of course, Im assuming both are VaisTech brand adapters. Other brands may work the same, though.
Walt
Old Apr 3, 2013 | 06:21 AM
Anniehow's Avatar
Anniehow
Thanks Walt!
I will offer that option up to my installer!
Gisele
Old Apr 3, 2013 | 07:40 PM
ECUJeb's Avatar
ECUJeb
I have the iSimple adapter. It has the option for two inputs as well. You could use an iPod and sat radio receiver.
Old Apr 6, 2013 | 08:20 AM
peteyx's Avatar
peteyx
The Vaistech will display 16 characters on the LS screen. The iSimple will only display 10.
Old Apr 7, 2013 | 07:28 AM
Anniehow's Avatar
Anniehow
I have the 16 characters, so I guess that means I have the Vaistech adapter.
dry-fly
Nov 22, 2013 05:38 PM
Ldenton23
Jul 6, 2011 07:15 AM
D.Jobin
Aug 28, 2008 11:50 AM
D.Jobin
Jul 21, 2008 12:28 PM
sbrown02
Nov 25, 2006 01:18 PM
