Problems!! CEL, VSC and Trac Off
Old Jul 1, 2012 | 09:07 PM
So Philly1's Avatar
So Philly1
Exclamation Problems!! CEL, VSC and Trac Off
Hey fellas. First off my apologies. I havent logged on it forever & i definitely have been neglecting my spaceship lately. I humbly come to you guys asking for help tho.
This past friday this stupid light came on in the car.
(I have no clue why the pic came out like it did, but you get the idea)
The check engine light, TRAC off light & Check VSC on the display. I googled everything. Some guy said a loose gas cap causes this. Tried..it didnt work. Others said other expensive problems. IDK fellas, i'm just looking for thoughts or anything before i take it to the stealership.
Lemme know what you guys come up with.
Thanks in advance
Old Jul 2, 2012 | 12:34 AM
RA40's Avatar
RA40
Super Moderator
This thread may have some insights.
https://www.clublexus.com/forums/rx-...ine-light.html
Old Jul 2, 2012 | 04:18 AM
yuri.ber's Avatar
yuri.ber
First off get codes read. After you know what it is you can fix the problem.
I had the same thing when oxygen sensor went. After changing one (top left), a month after another one (top right) went, lit up the same lights on dash. Changed it and no problems. Sensors were dealer OEM.
Old Jul 2, 2012 | 11:54 AM
Vpanin's Avatar
Vpanin
I had the check vsc light go on at start up. Turned out to be the mass airflow sensor
Old Jul 3, 2012 | 02:23 PM
So Philly1's Avatar
So Philly1
Ok guys...lil update. First off i called the dealer. They say $115 just to get a diagnostic. I almost hung up on the lady. Autozone reads codes for free. I went there. Guy says is a O2 sensor in bank 1. Before the catalytic converter.
It was like $90 bucks. I bought it & plan on taking it to my mechanic before the week is out. Unless you geniuses know an easy way to explain to me where bank one is. The part is just plug & play.
Got anything else?
Old Jul 3, 2012 | 07:03 PM
curiousB's Avatar
curiousB
Got anything else?
Buy a $9 O2 sensor socket and you can do it yourself in 20 minutes...
Old Jul 3, 2012 | 09:06 PM
mdt525's Avatar
mdt525
Got anything else?
You can change it but it is a birch to get to if you have large hands and if the car is not on a lift.
Posted from ClubLexus.com App for Android
Jeckel30
GX - 1st Gen (2003-2009)
May 29, 2017 03:25 PM
chico55
May 15, 2014 08:24 PM
brigoli
Jan 2, 2013 08:15 PM
pusan8
Mar 8, 2009 07:06 PM
HGill
Jun 15, 2007 10:28 PM
