Fuel door indicator
Old Oct 10, 2011 | 06:07 PM
64impalaSS's Avatar
64impalaSS
Default Fuel door indicator
I noticed the fuel door indicator is lit up on my dash this evening. I checked the fuel door and it is closed. I opened and shut it a few times with no luck removing the warning light. Maybe the switch is bad. I did replace the subwoofer today and took the back seat completely out of the car. I wonder if I could have accidentally unplugged something during that process. Does the fuel door indicator wires run inside the cab or outside. If it runs outside, I would imagine the switch went bad. Just seems weird it happened right after I got my car put back together. Any thoughts or advice would be greatly appreciated.
Thanks
Shane
Old Oct 10, 2011 | 07:57 PM
AlexusAnja's Avatar
AlexusAnja
can you take a pic? What are you saying is the "fuel door" indicator? I don't believe there is an indicator to show that the door is open. If you mean the little orange square under the fuel level indicator, that's to indicate your fuel is low.
Old Oct 10, 2011 | 08:38 PM
jayclapp's Avatar
jayclapp
I think the indicator is just a pointer that shows which side of the car the fuel door is on, depending of whether it is a left hand or right hand drive.
Old Oct 11, 2011 | 04:08 AM
2004TOYO's Avatar
2004TOYO
Thanks
Shane
Just curious, why did you take the rear seat out, just to replace the sub???
Old Oct 11, 2011 | 06:12 AM
64impalaSS's Avatar
64impalaSS
Made removing the package tray easier? I replaced it with a kicker 8 ohm speaker and had to drill new holes to secure the new speaker. From the research I have done on this site, that was the best method. You also have to do so to replace the rear struts.
Sorry for my ignorance, this is my wife's car, the fuel door indicator light just shows you which side the fuel door is on? I asked her if that light was on before and she had not noticed it. Maybe she over looked it the entire time. I can take a picture and post it if it helps. Thanks for everyone's help.
Old Oct 11, 2011 | 06:35 AM
Lust4Lexus's Avatar
Lust4Lexus
How does that Kicker compare to the OEM sub?
Old Oct 11, 2011 | 08:37 AM
caddyowner's Avatar
caddyowner
I thought this thread sounded familiar...
https://www.clublexus.com/forums/ls4...t-go-away.html
Old Oct 11, 2011 | 10:59 AM
64impalaSS's Avatar
64impalaSS
Thanks you Caddyowner, you are the man.
The new sub sounds great. Compared the old, not too much different as I thought the ML always sounded good until the old one crapped out. The quality of the new sub looks and feels much better, that is for sure.
VicAndRay
Jun 28, 2019 11:37 AM
BennyISF
IS F (2008-2014)
Feb 11, 2018 07:56 AM
dougm213
Jul 27, 2015 09:17 PM
YaYAReAGs3
GS - 1st Gen (1993-1997)
Jan 24, 2006 07:22 AM
