Mystery warning chime
Old Mar 21, 2011 | 08:00 AM
rkmorrow's Avatar
rkmorrow
Default Mystery warning chime
About once per day my 06 LS430 produces a warning chime with nothing on the dash to indicate what the problem is. The chime begins with a tone, then continues with a lower pitch bong about once every two seconds for about 30 seconds total. Then it quits for a while, and resumes with the same pattern of chimes after a day or so.
The passenger seatbelt warning light works normally and isn't related to the mystery chime since I hear it whether or not a passenger is in the car. The chime continues even after turning off the climate control, AFS, audio system, and park assist system.
The washer fluid was low, so I filled it but the chime persisted. (Again, no lights or warnings on the dash.) I disconnected the washer fluid low-level switch and the chime still persists. Any ideas?
Old Mar 21, 2011 | 01:03 PM
DDLexus's Avatar
DDLexus
are you wearing a seatbelt while driving?
Old Mar 21, 2011 | 02:13 PM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
i would call the lexus dealers service dept,they should know what the mystery chime is.
Old Mar 21, 2011 | 02:21 PM
svlexus's Avatar
svlexus
yeah its the seatbelt.
Old Mar 21, 2011 | 07:53 PM
rkmorrow's Avatar
rkmorrow
It's probably not a seatbelt warning since I'm always wearing it when the chime occurs. Also, the flashing seatbelt light on the dash turns off when my seatbelt is on, so the light is working normally. I've owned the car for two years and this just started happening.
Old Mar 21, 2011 | 08:51 PM
CarGuy89's Avatar
CarGuy89
Try to capture a video of the chiming, preferably from beginning to end. We might be able to better help you.
Old Mar 22, 2011 | 05:16 AM
lotus's Avatar
lotus
Do you have navigation? You or someone else can store points of interest and attach a sound byte to play when in proximity. Great for warning of traffic cams and such if you have the time to program them all in.
Old Mar 22, 2011 | 10:09 AM
rkmorrow's Avatar
rkmorrow
Thanks, lotus, that was a good clue to check the nav. Indeed the mystery chime always occurs when the car approaches the center of the small town near my home. The chime isn't related to any of the available audio nav alerts, and none of my programmed points-of-interest is anywhere near this town. The chime also doesn't occur when I drive through any of the other small towns in the area. No "areas to avoid" are programmed into the nav system.
I replaced the Gen 4 Nav DVD version 5.1 with version 10.1 a couple of weeks ago, and that's about the time this mystery chime began. It's still a mystery, but at least I know that it's related to the nav system. Now I need to figure out how to get rid of it since I drive though this town every day!
Old Mar 22, 2011 | 10:27 AM
caddyowner's Avatar
caddyowner
Tim Hortons paid good money to Lexus to have that alert sound.
DaytonaSTi
Apr 8, 2010 07:21 AM
afang
Nov 11, 2008 11:17 AM
DRivera250
Nov 28, 2007 01:54 PM
Bichon
Feb 27, 2007 08:39 PM
buggsc3
Mar 12, 2005 11:45 AM
