2003 LS Needs Engine
Old Oct 26, 2009 | 05:37 PM
ewhite's Avatar
ewhite
Unhappy 2003 LS Needs Engine
Here is the deal, drove my 2003 LS with 81.5K on it last Wednesday. Saturday morning started it and heard noise coming from under the hood. Shut it down, try restarting, no start. I get out and see smoke, smells like burned rubber. Since she is a 2003 certified LS with 81.5 on the odo with 7 months remainin, I called Lexus roadside assistance and have her towed in. BTW, I just had it serviced at 80K a couple of months ago. Advisor calls this evening and tells me they think it threw a rod and will probably need an engine. WTF? He says, "I've never seen this in all of my 5 years working here.". He will phone some type of inspector in the morning to get authorization to do the work. He also told me a new engine from Lexus in the crate is 25K. I know that's not going to happen. He has already located an engine with 65K on it, just waiting on the authorization. Glad my car is certified and that I've kept up with the maintenance. I can only imagine what this bill would have been when it's all said and done. I am just concerned if I will have the same ride, quietness, etc. Has anyone had an engine replaced?
Old Oct 26, 2009 | 05:53 PM
warminwisc's Avatar
warminwisc
25 g's huh? lot of dough! Does your policy specify they can use used parts(engines)?
Old Oct 26, 2009 | 06:06 PM
ewhite's Avatar
ewhite
Warminwisc, I don't believe the policy specifies, it just says the engine is covered. However, I will dig a little deeper to see what I can find out.
Old Oct 26, 2009 | 06:17 PM
Thermactor's Avatar
Thermactor
If the wrench spinning monkeys don't damage the motor mounts when replacing the motor, and line everything up right and don't break off any connectors while doing the wiring harness, it should ideally be just as good as before. If I were you, I'd demand a new engine because you're in warranty. Unless the warranty states that they'll put a junkyard motor in your car if the existing one fails, it doesn't seem fair to want to put someone else's junk into your expensive, certified pre-owned vehicle.
Old Oct 26, 2009 | 06:22 PM
AlexusAnja's Avatar
AlexusAnja
For something major like an engine or transmission, there will probably be provisions for "comparable" mileage replacement or "new" in which case they'll go with used. I would think for other things like starter, power window actuators, etc. they would use new and not used... Imagine getting a CPO vehicle and having a whole bunch of used parts put in eventually....
Old Oct 26, 2009 | 08:25 PM
Red Square's Avatar
Red Square
ive had a 02 with 42k swapped in to my 2001. during the swap they did damage one of the ac line, but they replaced it after i found out about it.
Old Oct 27, 2009 | 04:17 PM
ewhite's Avatar
ewhite
UPDATE: The warranty inspector told the dealer to tear down the engine to find out what happened before they will give them authorization to replace it. I was told the inspector just has to make sure this issue is no fault of my own, i.e., "I let someone do engine work and they left a bolt or something in the engine and that is what caused the problem." I also called the warranty company and was told the same thing. Dealer and warranty company basically said this is just formality. However, the dealer did tell me that it costs $1250 to break down the engine and if for some reason it is determined that the engine will not be covered I will be obligated to pay. This particular Lexus dealer is the only one that has touched the car since 55K and all of my maintenance has been done on time.
Old Oct 27, 2009 | 06:22 PM
caddyowner's Avatar
caddyowner
My son's Mazda 6 (2.3 I4 engine) developed an engine knock at about 31K. Mazda required oil change receipts, engine teardown, and pics of the damage to approve the warranty claim.
Old Oct 27, 2009 | 07:46 PM
AlexusAnja's Avatar
AlexusAnja
Okay, for those that do their own oil changes... who is really keeping the receipts? Plus, what if you buy "bulk" and have receipts for your mass purchases. How do you then prove that you changed it on schedule?
I hate warranty companies... I know it's their business to make sure there is no fraud, but some times it's just too much.
Old Oct 28, 2009 | 05:40 AM
toantran99's Avatar
toantran99
Wow, $25k for a new engine, you can get a used ls for that
Old Oct 28, 2009 | 07:46 AM
DNC's Avatar
DNC
I have never heard of a pre certified car owner having to accept a used engine or parts. If that turn out to be the case I would never do business with that dealership again, especially since they have done all your work.
I keep a detailed journal on all the work done on my car. I change the oil myself every 3,000 miles. My dealership says my handwritten journal is all the proof they need. If the element of trust doesn't exist we don't need to be doing business.
Old Oct 28, 2009 | 08:02 AM
caddyowner's Avatar
caddyowner
In my son's case, he didn't keep receipts but always had his oil changed at Firestone in the town where he lives. His step-dad was able to go to the store and get a printout which he faxed to the dealership.
Old Oct 30, 2009 | 12:24 PM
ewhite's Avatar
ewhite
Another Update: Dealer called today and said before they started to break down the engine, the mechanic started the car and it didn't make ANY noise. To make a long story short, they think it may have had carbon build up, even though I had that service performed in 2008. They want to keep it over the weekend for an extensive drive (50- 60 miles) to ensure everything is ok. I don't know what to think now. However, I do not drive the car too much. I only put 10K miles on it in the las 15 months. Will this problem rear its ugly head once the warranty is over in May 2010?
Old Oct 30, 2009 | 05:56 PM
ebolger's Avatar
ebolger
Sell the car now.
Old Oct 30, 2009 | 06:52 PM
mafpolo's Avatar
mafpolo
Angry Frustration With Lexus
Problem with a car that rarely ever breaks is - when it does break, Lexus doesn't know what to do.
