naviagtion error
Old Feb 1, 2006 | 08:47 PM
04whiteLS's Avatar
04whiteLS
Default naviagtion error
whats up guys newbie here i was playing with the programming and the navigation stopped working and is telling me that to insert the right version of the disc, i cant hit menu or a nything to get into the sytem program. ca anyone help me fix this problem
Old Feb 1, 2006 | 09:49 PM
rominl's Avatar
rominl
exclusive matchup
well what did you do to get to that error msg? you altered something in the hidden menu page?
Old Feb 2, 2006 | 06:29 PM
04whiteLS's Avatar
04whiteLS
yes thats what i did and now i cant get back into the hidden menu page to correct it
Old Feb 2, 2006 | 09:59 PM
rominl's Avatar
rominl
exclusive matchup
man you might be screwed.... you might need to take it back to dealership and see if they can fix it. the menu page is very dangerous if you don't know what you are doing
Old Feb 2, 2006 | 11:09 PM
encore888's Avatar
encore888
I wonder if the disc was ejected by accident.
Old Feb 3, 2006 | 01:10 AM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Question, if you unplug the battery, does the system go back to the default settings? if so, you should try it after trying to eject the disc and reinsert it again. You might have changed the region or something.
Old Feb 3, 2006 | 03:42 PM
04whiteLS's Avatar
04whiteLS
i took it to the dealer last week they siad theres no disc and that someone took it and the thing is im the only one that drives the car so its kind of hard to believe that unless one of them took it. but the thing is it says to insert the right disc not that there is no disc
Old Feb 3, 2006 | 04:22 PM
rominl's Avatar
rominl
exclusive matchup
well did you try to go to the trunk and eject the disc? (i believe that's where the nav unit is?)
Old Feb 3, 2006 | 10:03 PM
04whiteLS's Avatar
04whiteLS
i was going to i found where the unit is but it looks like its screwed down in a lil place and it looks like its blocked
Old Feb 4, 2006 | 11:37 AM
rominl's Avatar
rominl
exclusive matchup
umm there should be a door or something and an eject button, no? at lesat that's the case for gs and sc430
Old Feb 4, 2006 | 04:42 PM
mink92890's Avatar
mink92890
In order to remove the unit, remove the two screws on both sides of the unit. It is supported by two U-shaped arches that carry on to the bottom of the floor. When you remove it, just put your hand under the unite and with both hands gently push up to reveal the slot and the eject button. When I removed the unit, there WERE some squeaky noises so dont be scared. There is a CD-like slot where the DVD will be located. Next to it is a plastic like switch which can be moved to the left or right. Move it to the direction it is not already in and it will reveal the eject button. The only problem with checking this, at least for me was with putting back the unit. When you put it back it is very harsh and some force is required. Like I said earlier, do not be afraid when you hear these squeaky noises. It is not as easy as it seems, at least for me. But I had no prior experience with doing anything in the car.
Good Luck
Mink92890
Old Feb 4, 2006 | 05:04 PM
04whiteLS's Avatar
04whiteLS
thanks ill try it tonite
Old Feb 4, 2006 | 05:48 PM
mink92890's Avatar
mink92890
If you have any additional conditions, just post here... If not today, i will keep on checking tomorrow...
Mink92890
Old Feb 5, 2006 | 10:37 AM
rominl's Avatar
rominl
exclusive matchup
very nice instructions there mink, awesome!
Old Feb 5, 2006 | 06:55 PM
mink92890's Avatar
mink92890
haha thanks. great to be complimented my mr 35000 posts
Mink92890
