Need help a few codes/problems :) please
Old Aug 11, 2020 | 01:31 PM
MTVRandy's Avatar
MTVRandy
Default Need help a few codes/problems :) please
So... I’m new to the Lexus community and posting on here so sorry if I did anything wrong.
I have a 1995 LS400 autozone says it’s a 96 for sum reason... I have a few codes/problems the car is throwing a MAF sensor code (put a brand new maf sensor still throwing code) a EGR code and a knock sensor code (bought the knock sensor will be doing it this weekend) the car is burning super rich I’m probably getting 7mpg or less I’m posting this to get any help i don’t know if the 1 knock sensor is going to solve all the problems but I doubt it the car also doesn’t rev all the way like it’s lack in power or somthing and 2/3 times it starts up but dies but right after I start it again and it’s starts fine it also doesn’t feel as fast as it should be but it does drive once again I’m posting this to get some input thanks.
Old Aug 11, 2020 | 01:44 PM
Sin1UZFE's Avatar
Sin1UZFE
I think those years ECUs become problems.
Old Aug 11, 2020 | 01:49 PM
MTVRandy's Avatar
MTVRandy
the owner before me told me he took to to refresh the ecu at the dealer or something like that
Old Aug 11, 2020 | 04:40 PM
Yamae's Avatar
Yamae
I worry that the ECU was not properly fixed. Check the ripple voltage level as is explained in the FAQ page. Or simply see inside of it and check that all QAS capacitors are changed to good low ESR ones that are listed here. QAS capacitors are all printed Nichicon PF(M) or PR(M).
Old Aug 11, 2020 | 05:21 PM
MTVRandy's Avatar
MTVRandy
I’ll be sure to check that out on the weekend as well when doing the knock sensor and the knock sensor can’t be the cause of all this right?
Old Aug 11, 2020 | 06:04 PM
Yamae's Avatar
Yamae
This is just my guess but what the owner before you have done was the firmware update. A 95's ECU was needed to update the firmware or to change the ECU due to the reason that the car has a engine halt problem.
There was a TSB that said about this and the firmware was mostly updated and marked. Another TSB said, "89661-50224 should be used replacing 89661-50220 (factory installation 10/1994-02/1995) / 89661-50221 (factory installation 02/1995-08/1995) as a countermeasure for the engine halt problem at certain conditions. For California, 89661-50234 is used replacing 89661-50230 / 89661-50231.
Anyway, you can find more seeing the ECU removing it as is shown here.
Old Aug 12, 2020 | 02:00 AM
Sin1UZFE's Avatar
Sin1UZFE
Any reputable ECU repair shops that we can ship to?
Old Aug 12, 2020 | 02:18 AM
Yamae's Avatar
Yamae
Since I always do like this girl
and I have never shipped to any shop. So I have no idea to reply your question.
DonTripp
Aug 9, 2020 05:59 AM
qwerty04
Jan 29, 2012 11:32 AM
hyhflo
Dec 28, 2008 06:29 PM
gazi001
RX - 1st Gen (1999-2003)
Sep 10, 2007 08:10 PM
