LS400 Stalls only when braking
Old May 16, 2019 | 03:43 PM
peterls's Avatar
peterls
Default LS400 Stalls only when braking
Just fixed one thing and there comes another...
Today, on my way from work, I noticed that steering became stiff few times. Seemed random, until the car stalled. I drove carefully from that point on and noticed that the harder I brake, the more the RPMs dip, and if I brake hard, or even medium-hard (like when someone cuts you off in traffic), then the car wants to stall. So I had to push it to N every time I hit brakes, to ensure the car doesn't stall.
After a stall it restarts no problem. It also accelerates no problem. Everytihng's fine, only it does not like braking.
Any ideas?
ps. I had one of the two Bosch rotors/housings replaced a couple of months ago - it broke and one side of the engine didn't work at all (limped home for about a mile that time). The mechanic pulled a fast one on me and replaced only that one rotor, when I asked him to do both. Could a failing rotor/housing be the cause?
Old May 16, 2019 | 03:54 PM
peterls's Avatar
peterls
Just did a google search (works a lot better than this one), and found my own post from 5 yrs ago:
https://www.clublexus.com/forums/ls-...to-a-stop.html
So I will try that first
Old May 16, 2019 | 10:51 PM
peterls's Avatar
peterls
Just finished cleaning IACV and the problem is gone. So, the cleaning period seems to be about 4-5 yrs.
Old May 17, 2019 | 04:17 AM
Fit1too's Avatar
Fit1too
Glad it worked out. Thanks for letting us know!
Old May 17, 2019 | 10:14 AM
oldskewel's Avatar
oldskewel
Fantastic. Asked a question. Gave yourself a suggestion including a linked thread ... that referred to a problem you had previously ... posted to confirm the solution.
Fully self contained thread. Nice! But you're doing all the work - give someone else a chance, maybe.
Glad you got it fixed, and thanks for the case study.
Old May 17, 2019 | 10:58 AM
peterls's Avatar
peterls
A recursive thread, we could call it.
Old May 17, 2019 | 11:01 AM
peterls's Avatar
peterls
BTW, if anyone is doing this (cleaning the IACV), you may find a little, funny looking ring at the very bottom of the IACV, under the little bearing inside. If it falls out, you won't know which way it goes, and ONLY ONE WAY IS RIGHT!
Guess which way I put it back in last night... the wrong way, obviously (you can tell because your idle will be going up and down like crazy). The right way is for the edges of that ring to be raised, not the center. You can see the orientation of that ring on planet soarer site where he has a nice write-up with pictures about cleaning the IACV (one of the last pictures shows just enough of that ring so that you can tell how it should be oriented).
Fishdoc2
Dec 13, 2017 05:43 PM
blackbob
Feb 1, 2009 06:17 PM
CrazyHawaiian
May 18, 2007 11:44 PM
Lex_LS400
Apr 23, 2003 12:50 PM
SupraCoup3
Dec 24, 2001 07:21 PM
