Lower Control Arm Play
Old Feb 26, 2019 | 03:48 AM
Moarpower's Avatar
Moarpower
Default Lower Control Arm Play
Hi guys. I have to replace the lower control arm bushings in my Celsior. They have quite a bit of play at the moment.
last week the front left coil over went out. Fluid everywhere. Now I feel rattles bad in the steering wheel. Tie rod ends, upper control arms all seem fine. Lowers are moving half an inch.
I would like to just replace the bushings but is it even worth it as they are still expensive. Anyone Know of any half decent , affordable aftermarket options for tese ?
I probably won't go own for this as this isn't my main car anymore.
Old Feb 26, 2019 | 08:52 AM
timmy0tool's Avatar
timmy0tool
as for aftermarket all I am aware of is ADUS. are you referring to the strut rod bushing? or the lower control arm bushing that meets the subframe (where the eccentric bolt is to adjust camber)?
this is the strut rod.
https://www.clublexus.com/forums/sho...&postcount=133
https://www.clublexus.com/forums/ls-...ock-noise.html
most stick to OEM bushings however to keep the plush ride.
Old Feb 26, 2019 | 04:16 PM
Moarpower's Avatar
Moarpower
No it's the lower control arm bushings itself.
the others are all good for now.
as for the plush rides I don't have that anyway.
Old Feb 26, 2019 | 04:37 PM
Sin1UZFE's Avatar
Sin1UZFE
Same here, its already much nicer than what I had/have.
Old Feb 28, 2019 | 09:04 AM
EthanS's Avatar
EthanS
I recently replaced my lower control arm bushings (not strut rod bushings). The play in the passenger side was terrible. I could hear it sliding/knocking around every time I went up or down my driveway curb.
Used "Febest" brand bushings from Amazon. They were $18 each.
I had coilovers installed before and after the bushing replacement, but I'll tell you that I noticed a dramatic improvement because the passenger bushing was completely deteriorated. Driver's side bushing wasn't nearly as bad but was worth changing too.
I guess I'll note that at the same time I replaced lower control arm ball joints too. I used Moog units. No complaints.
Old Feb 28, 2019 | 03:08 PM
Moarpower's Avatar
Moarpower
Thanks Ethan.
could you find a link to those bushings please? I'm also tempted to buy a bushing kit for around 300 aud
Old Feb 28, 2019 | 03:51 PM
Sin1UZFE's Avatar
Sin1UZFE
Thanks Ethan.
I cant find febest but I found all these
Amazon Amazon
Old Feb 28, 2019 | 06:57 PM
Moarpower's Avatar
Moarpower
I'm confused. Why are so many parts called a front lower control arm bushings but so many look like totally different parts .
Old Feb 28, 2019 | 11:40 PM
Losiracer2's Avatar
Losiracer2
I used the Febest ones as well on my 97 and they're doing fine 25k and 2 years later. I live in Michigan where there are ****ty roads with potholes everywhere and they still handle the abuse.fine and haven't torn or fatigued.
Old Mar 1, 2019 | 04:15 AM
Moarpower's Avatar
Moarpower
OK thanks guys. I'll try to find a way to get them here in aus.
they range from cheap to ridiculously expensive so I want to just buy what's good, not what's most expensive or cheapest. Diminishing returns would certainly apply to a rubber bushing.
cbgdjg
Jan 26, 2017 04:33 PM
downrigger
Dec 5, 2013 10:59 AM
Lavrishevo
33
Jun 5, 2013 07:53 PM
fonebone
Suspension and Brakes
May 15, 2013 10:49 AM
OutlawTita
May 22, 2008 01:07 PM
