Traction Control Problems
Old Sep 30, 2018 | 04:47 PM
8NUGE3's Avatar
8NUGE3
Default Traction Control Problems
Hey all, so I got a 95 LS400 I got from a trade. Trac light was blinking and I ran a scan and got a code for sub tps sensor. I replaced the sensor but I’m still having issues. When I start the car I can hear the butterfly plate in the TB clicking for about 10 seconds. For that brief period of time I can turn the trac on and off but once the clicking stops the trac light goes back to blinking and I’m no longer able to turn the trac off. I also noticed what I think is called a throttle cable that was damaged and not even connect to what it was supposed to connected to. Maybe not a main one I guess. It starts from the back left of the engine bay if your facing the car from the front and connects to the part in the middle where u can open the throttle manually. I replaced that as well. I’m trying to figure out what is causing this clicking , and how I can fix that and get my traction control system working so I can turn it off whenever I want. Any help, info, or direction would be greatly appreciated!!
Old Sep 30, 2018 | 04:49 PM
8NUGE3's Avatar
8NUGE3
Just to add, I replaced both tps sensors. Haven’t adjusted them properly as I don’t have the tools required.
Old Sep 30, 2018 | 05:56 PM
AlaskanLS's Avatar
AlaskanLS
You don't need any special tools other than philips head screw driver to adjust throttle position sensor. Once your car's engine reach operating temperature, you can adjust the throttle position sensor by hand and move it to the position where your tach needle show 650 rpm. Then tighten it. Forget about feeler gauge or multi-meter.
Old Sep 30, 2018 | 07:22 PM
8NUGE3's Avatar
8NUGE3
would 650 rpm be in park or in drive ? I was messing around with them with the screws loosened enough to move it but I was getting no change in rpm. Do you think this is why my TB is clicking on startup ?
Old Sep 30, 2018 | 07:49 PM
Yamae's Avatar
Yamae
Are you sure on that method?
As far as I remember, without thickness gauges, you can't adjust those 2. The detail is in the manual below. The idle rpm is fully controlled by the ECU after mechanical settings are properly done in accordance with the correct procedures.
https://techinfo.toyota.com/techInfo....toyota.com%2F
Old Sep 30, 2018 | 07:52 PM
AlaskanLS's Avatar
AlaskanLS
Oh my friend, how are going to adjust TPS while it’s in drive?For that you may have to sit on the top of the engine and let someone put in drive and you adjusting the TPS.
Of course it has to be in either park or neutral.
Old Sep 30, 2018 | 08:17 PM
8NUGE3's Avatar
8NUGE3
lol I just remember reading somewhere about doing it in drive with a second person. Foot on the brake of course. Moving the tps from one end to other isn’t doing anything for my idle Rpms...
Old Sep 30, 2018 | 08:32 PM
AlaskanLS's Avatar
AlaskanLS
It should respond to TPS. Have you bought a new aftermarket TPS or used eBay TPS? Clean the throttle body with throttle body cleaning spray. The clicking noise from butterfly valve you are talking about, it sound like loose butterfly valve. Can you check and make sure your car's throttle body is operating normally.
mon112387
Jun 10, 2012 10:18 AM
sc101
Jan 25, 2012 09:54 PM
jdog0411
19
May 24, 2011 08:09 PM
smokeganja
Jun 12, 2008 02:01 PM
Black_IS300
IS - 1st Gen (2001-2005)
12
May 23, 2001 09:36 PM
