93 LS 400 code 31,41 and 47
Old Aug 7, 2017 | 08:42 PM
Karlos1uz's Avatar
Karlos1uz
Default 93 LS 400 code 31,41 and 47
Hey guys I'm new here and i hope I can get some help.
i have an 93 ls400 getting code 31 Maf,41 tps and 47 sub tps, and at first start smog withe and smell like gas and missfire,after 10 minutes idling smog goes away but cars feels like in limb mode, some times check engine light doesn't light up when you put ignition, i check fuses and all are good. After I erase the codes removing EFI fuse , the codes come back after first test drive.. any suggest before I start changing some parts??
Old Aug 9, 2017 | 07:02 AM
Yamae's Avatar
Yamae
I'd check the ECU capacitors when unrelated multiple codes were read.
https://www.clublexus.com/forums/ls-...capacitor.html
Old Aug 9, 2017 | 07:38 AM
Moarpower's Avatar
Moarpower
I had white smoke on start up and revving, Mine would idle ok until it reached operating temp and then the idle would bounce down and back up. First things first. Change the AFM. It fixed the problem I mentioned form me. Also remove and clean your IDLE AIR CONTROL VALVE and Throttle body. Remove and reset the TPS. See how you go.
Old Aug 10, 2017 | 01:48 PM
Karlos1uz's Avatar
Karlos1uz
Default 1993 LS400 code 31 and 47
Update,,
I did check continuity from both tps and afm to ecm and wiring was good no broken wires,so I cleared the codes and check engine light is on right away after 5 seconds of engine running so I decide to try with different afm and and guess what?? That was my problem, no check engine light and engine running smooth again.
Old Aug 10, 2017 | 02:37 PM
Moarpower's Avatar
Moarpower
Originally Posted by Karlos1uz
Update,,
BRILLIANT!! that's good to hear.
Old Aug 10, 2017 | 09:48 PM
dicer's Avatar
dicer
Sounds like someone cleaned the first one then. Don't clean it ever.
archalis
Sep 30, 2018 01:07 PM
Boojie97
Feb 22, 2018 11:02 AM
xmssc300
Dec 13, 2012 09:57 AM
Gator3
Aug 25, 2008 07:59 PM
fowcbler
Apr 18, 2008 09:48 AM
