98-00 Power steering filters?
Ive searched but can only find stuff for pre 97. Ive removed the 12mm bolt from the solenoid and I can get it to rotate but cant get it off, does it just pull out? Dont want to use anymore force then I already am until Im sure that how to get it off
No filter on 1999 ls400 power steering rack solenoid
Removed Power Steering Rack Solenoid:
A single 12mm hex bolt and turn body gently side to side while pulling solenoid out.
It resembles a larger version of a VVTi solenoid.
No filter screen on the solenoid or valve body bore.
I did notice a few very fine flecks of metal in the fluid in catchment pan.
Anyone know whether the power steering fluid reservoir on 1998 - 2000 LS400 has a filter screen?
If so then probably worth removing reservoir to clean screen.
