92 LS400 Wire Problem
Ive had my car for 2 years. Yesterday the battery was dead so i pit a box on it. When i turned the key the starter clicked and lost power. When i went to reconnect the box there was major sparks. Anyway i unbolted the starter wire from the cables and no sparks. So i pulled a wire diagram for the battery and the wire that i took off the battery ris directly to the starter. Could this be a problem with the starter or is the wire just hitting grond somewhere?
Dale, when you say you put a 'box' on it, I assume you mean a charger or booster box?
The cable SHOULD run directly to the starter, so that is normal. There is also a smaller wire that energizes the starter solenoid.
If you are getting major sparks, that suggests major current draw. Could be something shorted, perhaps the starter itself is bad (shorted). How many miles are on the car?
Yea I used a good jump box. When you try to connect it it sparks so much its like touching the cables together. I just wanted to make sure that the problem was in the starter before i start taking it apart. It has 147,000 miles
Oh, another thing to check carefully...I know it sounds too simple...but make sure that you are putting the correct polarity on the battery from the jump box. It just does not make sense to have major sparks unless the polarity is reversed. May be that the box got incorrectly marked.
I would put a slow trickle charge on the battery overnight to see if it would at least charge.
kohlex
Sep 20, 2012 12:38 AM
