Diagnostics??
Old Apr 17, 2014 | 03:03 AM
DrifterJ's Avatar
DrifterJ
Default Diagnostics??
Well I found a 24 hr. AutoZone, figured I'd change my plugs and wires since my car has a rough idle and poor acceleration (it feels like a dead cylinder). Bad idle, vibration through out.
Fuel system should, *SHOULD* be ok since I had the fuel pump replaced, IACV has been replaced over the summer of last year. So leaves me to believe a vacuum issue or plugs and wires. May be an injector or MAF sensor.
Im not throwing a CEL but I decided to use the jumper wire method since I dont have an OBD1 scanner. No CEL still. I knew i was on the right track because the trans diag. was blinking, but no issues there.
Is there somthing im missing? AC off, throttle closed, radio off...Im baffled
Old Apr 17, 2014 | 03:16 AM
DrifterJ's Avatar
DrifterJ
I should probably note that I own a 92 ls400...
cgawelko's Avatar
cgawelko
24 hour autozone means you went to 43rd ave and Cactus. your in my neck of the woods.
how are your coils and ignitors?
Old Apr 17, 2014 | 03:18 AM
DrifterJ's Avatar
DrifterJ
Lol, yeah i am cgawelko. Im at 27th and Yorkshire, right behing AMC 30 and Target and such.
I have yet to check the coils and ignitor.
Not sure how to, to be honest.
Old Apr 17, 2014 | 03:19 AM
cgawelko's Avatar
cgawelko
im down by Glendale 9, but im out that way all the time. work over at Mill though....
This post is from LSCowboy on another persons thread, and it shows step by step how to check them on a LS400 specifically. Skip toward the end, the beginning part is just a bunch of talking :P
Originally Posted by LScowboyLS
here is a handy test demonstrated on an LS400 just like yours, that will check your ignitors, coils, and the associated wiring to each!
igniter bypass test
Old Apr 17, 2014 | 03:21 AM
DrifterJ's Avatar
DrifterJ
Right on dude, we should meet up soon. I'd love to meet a fellow lexus owner.
Im still new to these cars.
Old Apr 17, 2014 | 03:24 AM
cgawelko's Avatar
cgawelko
I am too new as well, only had mine about a month. sometimes I go out to the street racing gatherings and such, but lots of rice hangin around there and Lexii loves rice lol
Old Apr 17, 2014 | 03:28 AM
DrifterJ's Avatar
DrifterJ
Hahaha, ok cool. I've gone through my street race phase, found out its childish lol.
anywho, i just watched the link you posted. helpful, im gonna have to try that this weekend. see if my buddy will let me borrow his volt meter and grab a test light.
Old Apr 17, 2014 | 03:32 AM
cgawelko's Avatar
cgawelko
volt meter and test light wont be more than $15 for the two at Autozone. should be $7.99 for the volt meter and $3.99 for the test light. Aisle 2, right side, right at the front of the aisle.
Old Apr 17, 2014 | 03:33 AM
DrifterJ's Avatar
DrifterJ
Thanks for the help buddy, and the quick response. It's my daily so i need next to no down time. Full time student, and going to be starting work soon in tempe.
Old Apr 17, 2014 | 03:40 AM
cgawelko's Avatar
cgawelko
so you will be working on my side too! and no problem, its what I do. Im currently at work and this is what I get to do on my spare time lol
Old Apr 17, 2014 | 05:12 AM
Gene01's Avatar
Gene01
For this work (and most automotive testing), you can use the cheapest digital voltmeter you can buy.
Harbor Freight frequently has them on sale for $2.99 or even free on occasion.
Then, you don't mind so much when the batteries leak after leaving them in the hot trunk for three years :-)
I actually prefer the old style VOM which don't require batteries unless you need to measure resistance (ohms).
Old Apr 17, 2014 | 01:31 PM
DrifterJ's Avatar
DrifterJ
Thanks Gene01, I'll go and see whats out there, every tool box does need a volt meter lol. I used to have one, but a friend of mine used it more than i did, so i gifted it to him.
Old Apr 17, 2014 | 01:32 PM
DrifterJ's Avatar
DrifterJ
Yeah, man, Direct Energy is on University and 52nd street, we're not going to be too far lol
Old Apr 17, 2014 | 01:48 PM
cgawelko's Avatar
cgawelko
Im at Scottsdale and Weber lol. so literally 4.2 miles away. ill probably see you on the freeway if you work late at night because I go to work around 1030. You will know, its the lexus with yellow middle lights and then regular headlights, usually in the HOV going a touch over the speed limit
IndoCaviar
Performance
Jan 12, 2019 05:25 AM
mbaughman1
Oct 3, 2017 06:38 AM
malgus270
Feb 1, 2016 05:42 PM
jporchia
Oct 29, 2013 08:29 PM
O. L. T.
Jan 21, 2013 09:02 AM
