99LS Warning light
Old Aug 16, 2013 | 05:40 AM
UNCNOR's Avatar
UNCNOR
Default 99LS Warning light
Warning light for low washer fluid came on this morning.Reservoir is full of fluid.Light will not turn off .Is this a sensor problem or a float problem?
Can an amateur fix this or does it have to go to a shop?Thanks for your help guys.
Old Aug 16, 2013 | 06:05 AM
billydpowe's Avatar
billydpowe
well an amateur can do it, take the Reservoir off, hold it upside down, if the light goes out, it is a float problem.
ps, have you tried doing a search?? and then tell us what you found...
Old Aug 16, 2013 | 07:12 AM
UNCNOR's Avatar
UNCNOR
Tried a search prior to starting thread.Found an old thread posted by a bunch of comedians.Will try the upside down approach this weekend.
Old Aug 16, 2013 | 04:36 PM
Yamae's Avatar
Yamae
This is just my experience but I suggest you to hit the reservoir using a wood hammer or something equivalent. You need to hit it rather strongly but don't break the reservoir.
When aged, the sensor's contacts are prone to stick. Replacing the sensor is the best way to fix but just hitting can fix it. I have tried this for several Celsiors and all of them were fixed.
Old Aug 17, 2013 | 01:13 PM
steve2006's Avatar
steve2006
Check post no. 6 for the fix.
http://www.lexusownersclub.co.uk/for...=washer+bottle
Old Aug 17, 2013 | 01:21 PM
anesthesia's Avatar
anesthesia
This is a very common issue, I just disconnect it for past 7 years
Old Aug 17, 2013 | 02:16 PM
dc893's Avatar
dc893
That's what I would do. Not like it's an important sensor.
Old Aug 17, 2013 | 02:38 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
Same for me. Unplug, zip tie out of the way, check fluid every couple months.
Old Aug 17, 2013 | 04:48 PM
Lavrishevo's Avatar
Lavrishevo
When mine would come on on my 99, usually when I hit a big bump in the road I would pound on the top of the refill the cap and that usually released the cork or whatever is in there.
Hexxle
Dec 2, 2012 08:24 PM
alexpro
Oct 12, 2011 09:23 PM
luda42688
May 4, 2011 07:30 PM
johnnybmw1
Jun 11, 2009 11:40 PM
xbukeye
Feb 26, 2009 10:08 PM
