ucf 20 celsior problems
Old May 7, 2013 | 06:28 AM
fecker's Avatar
fecker
Default ucf 20 celsior problems
I live in japan and not speaking japanese its vary hard to get information i have found some fixes on here and im going to try them this weekend one new problem i have is the trac off light keeps coming up now when i was cleaning the throtle body i removed the sensor on the first buttfly valve i am wondering if there is a special way to put it back on. i went to a toyotpet to get the ecu reset to stop the trac off light from blinking they told me i would have to replace the throtle body. after they reset it i left turned off my car went into a store got back into the car turned it on and the light started to blink agian. i also have the powersteering problem wondering if its a oring on the hose the leak looks to be coming from the bottom of the pump where the hoses goes in any info on parts needed to fix that would be great. the stalling issue after long drives hopefully the added vacume line works ill try that this weekend. also whats a good size navi to install. thanks for any information.
Old May 8, 2013 | 06:45 AM
fecker's Avatar
fecker
today i did some troubleshooting on the throttlebody.since yesterday they told me the whole throttle body assy had to be replaced i turned the car on then removed the plug from the first sensor nothing happened i then pluged it back in removed the second sensor and the idle changed so maybe the first senor is bad im not sure however when i turn the car on theres a clicking noise coming from the front half of the throttle body like the sensor disengauged more troubleshooting on the problem later im thinking its something electrical on the other side of the throttle body by the firewall if anyone has any ideas of what to replace besides the whole throttle body please tell
Old May 8, 2013 | 10:43 AM
timmy0tool's Avatar
timmy0tool
what year is the car? it may vary in japan from our cars here in the states but half of the UCF20s did not have VVTi (95-97) and the other half does (98-00).
Old May 9, 2013 | 03:14 AM
fecker's Avatar
fecker
its a 95 or 96 (the is vvti is right behind the filter box right) if so that looked cleanned the throttle body makes a click then an unwinding sound after startting the engine. the dealer said i needed a new throttle body which i think is bs
thank you for the post
Old May 9, 2013 | 08:12 AM
Yamae's Avatar
Yamae
Originally Posted by ******
i went to a toyotpet to get the ecu reset to stop the trac off light from blinking they told me i would have to replace the throtle body..
Why don't you try to replace the throttle body? They are now only 2-3K Yen these days in Japan.
http://auctions.search.yahoo.co.jp/s...ab_ex=commerce
Incidentally, I have a little hard time reading your English.
Old May 9, 2013 | 11:24 AM
timmy0tool's Avatar
timmy0tool
95-96 cars do NOT have VVTI, and it's not next to the filter box. VVTI stands for variable valve timing which is a function inside the motor and valve train. since you have a non-VVTI motor, i would change the throttle body as well since it's much cheaper. from what i know in japan the dealers are fairly honest.
Old May 10, 2013 | 05:14 AM
fecker's Avatar
fecker
how much is a throttle body where you guys are they want over $1000.00 here from the dealer
Old May 10, 2013 | 08:01 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
buy a used one...
Old May 11, 2013 | 04:20 AM
Dutchy's Avatar
Dutchy
Contact with Yamae. he is a very kind Japanese man, and always willing to help. Look at his Link, those are second hand. otherwise try ebay.com.
Old May 13, 2013 | 11:43 PM
LScowboyLS's Avatar
LScowboyLS
answer: about $200-$300 in Japan as Yamae stated:
Old May 14, 2013 | 04:51 AM
Yamae's Avatar
Yamae
No, it is not that expensive. 2-3K Yen is 20-30 US dollars. Because 100 Yen is about 1 US dollars now.
Old May 14, 2013 | 09:02 AM
LScowboyLS's Avatar
LScowboyLS
oops, that was a typographical error on my part I know the exchange rate very well, I buy items from yahoo auctions in Japan!
Old May 16, 2013 | 07:04 AM
fecker's Avatar
fecker
the trac control sensor is not adjusted correctly. The throttle body is fine. I'm thinking about trying to set it but I just bought a juction exhaust. I have the new toy iich spent all day trying to find a muffiler hanger and mount. The original muffler mount uses two rubber orings holding the muffler in place. the new muffler has a straight with a 90 deg bend, the old mufler had a hook. since the new muffiler does not have a hook im going to use a u-bolt and attach that to the muffler mount. this will allow me to use the correct muffler rubber hanger and not have to worry about it falling off.
Max Power
Nov 8, 2010 06:06 PM
nchavez430
Dec 3, 2009 06:34 PM
JDMCelsior
Feb 7, 2008 04:35 AM
Orkin
IS - 1st Gen (2001-2005)
Jun 25, 2001 03:06 PM
