BC Coilover install this weekend
Old Aug 11, 2013 | 09:01 AM
  #46
davecarter's Avatar
davecarter
What spring rates are you running Rasimmo, the 12kg/8kg off the shelf BC option? I'm eyeing off a set of BCs for mine and am unsure as to whether 12/8 will be too soft. I won't be going super low as it will be going on 19s and is my daily so would like to retain as soft/close to stock a ride as possible while gaining height adjustment.
Old Aug 12, 2013 | 05:57 AM
  #47
Rasimmo's Avatar
Rasimmo
Yea the stock rates...but I'm switching to 18/16k soon. The stock rates are way too soft for the Ls... I think BC does that on purpose lol jus so you have to buy stiffer spring...
Old Aug 20, 2013 | 09:38 AM
  #48
OKSTANCE's Avatar
OKSTANCE
its pointless spending a grand on bc coilovers if you are just wanting out of the box specs.. IMO a waste of money
Old Feb 24, 2014 | 05:36 PM
  #49
oldyota's Avatar
oldyota
Yes I know this is an old thread but I plan to do an install this weekend as well and my research has led me to ask the question.
Is this necessary for extreme drop. If so do you have pictures of said hole? and modifications
thanks guys.
Originally Posted by usoff89
^^^^ What he said! The bottoming out sound your hearing is most likely the a-arm hitting the shock tower. Depending on how low you are, you WILL have to cut a hole in it for it to pivot in and out of. I cut about a 4x4inch hole on each side, and it stopped hitting (bottoming out sound).
Oh, and if you are low enough to hit the tower, you also need to move the harness on the driverside. The tire could rub threw it, and you will have a ton of problems.
Savixor
IS F (2008-2014)
Mar 7, 2018 02:12 PM
itzhieu
Apr 16, 2013 09:46 PM
Brian S
23
Apr 28, 2005 12:43 PM
